MCX preference will only working at 'every login'
  • May 17, 2012
  • 22 replies
  • 34 views
We are in the process of migrating from OD to Casper MCX. (JSS 8.43)
We have an issue with a couple preferences. For instance: .GlobalPreferences - Show All Extensions. Even though they are set to 'next login only' will act as if its set to every login.
This will occur on 10.6 and 10.7. Occurs on our live JSS and dev JSS. Flushing the MCX cache does not help either.
Any ideas?
PS: the complete.plist file within /Library/Managed Preferences/ gets re-created everytime at login??
  • May 17, 2012
This actually happened with our Desktop Background MCX as well. I'm kind of curious to see if anyone has been able to resolve this.
bentoms
Forum|alt.badge.img+35
  • May 17, 2012
Saw this too. (with the desktop background).
I temporarily fixed by removing & then reading the mcx.
Forum|alt.badge.img+15
  • May 17, 2012
I'm seeing this as well with dock items. Jamf reproduced it and filed a defect for me so I'll be watching the release notes of the next update.
  • May 17, 2012
The defect numbers are D-002808 and D-002809
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • May 17, 2012
Interesting. MCX "next login only" was broken in 7.2x, fixed in 7.30 and broken again in 7.31. It's broken again in 8.43?
Seems to be a recurring problem.
  • May 18, 2012
We also replicated the problem on our dev box in 8.52
  • May 18, 2012
After further troubleshooting. Local accounts are not affected. Only AD network accounts. Any ideas?
  • May 18, 2012
we are seeing the same thing with AD accounts here.
  • May 21, 2012
+1
  • June 6, 2012
Woo Hoo! It's not just me! Hopefully this is resolved soon so i'm not constantly resetting changes users are making.
  • August 23, 2012
Not to revive an old thread, but has there been any known resolution to this? I'm seeing this too with a screensaver MCX setting, specifically setting the default module. Its set to User Level at Next Login Only and I'm seeing it get applied at every login. We've moved to 8.6 of the JSS, and I'm still seeing it. I deleted and recreated them, but the setting still gets pushed every time to our Macs, so apparently this wasn't fixed in 8.6? For something like a screensaver, its just an annoyance, but could pose bigger issues for other MCX settings.
talkingmoose
  • Community Manager
  • August 23, 2012
My only comment is that this is more a problem with JAMF's QA testing. They're repeatedly not catching it and their development keeps breaking it.
This specific issue has been bugged since at least Casper 7.2, fixed, bugged again, fixed, bugged again... I think this is the fourth or fifth time now.
I suggest complaining to your account manager about this one and pointing him or her to this thread.
bentoms
  • September 5, 2012
Still seeing the issue here, i'm using the below to test:
Display Name: Magic Mouse 2 Button Application Domain: com.apple.driver.AppleBluetoothMultitouch.mouse Key Name: MouseButtonMode Key Type: string Key Value: TwoButton
JSS is 8.6, clients are 10.6.x, 10.7.x & 10.8.x.
The once setting works "sometimes" if all users do is logout then back in. So they change the setting, log out.. log in & it's still changed.
But if they do a restart, the setting is often reapplied.. it's like the Mac on a restart contacts the JSS for the MCX settings.. then re-applies them.. :(
This also seems to be with only AD mobile accounts, our local admin account is not affected (it's our only local account).
Onto account managed now!
  • April 30, 2013
Hello,
Unfortunately this bug still seems to be alive and well in Casper 8.64.
I have spoken to our account manager at JAMF and he has confirmed that this is currently marked as a defect.
Has anyone managed to find any workarounds to this issue?
Thanks
Tim
  • May 1, 2013
This was only affecting me for dock management. I completely ditched using MCX for dock management and moved to a logon script using dockutil. It's worked well, but I did have to invest some significant time into getting dockutil to do everything I wanted.
bentoms
  • May 1, 2013
Have a look @ my feature request, https://jamfnation.jamfsoftware.com/featureRequest.html?id=45
Also look @ the jamf login hooks.
JAMF MCX is refreshed @ every login & so once works the same as often.
  • May 1, 2013
Dockutil is awesome! I am also needing MCX primarily for customised docks for our various different teaching departments... about 15 all with completely different docks. This could be painful but it may be the only way!
Have a look @ my feature request, https://jamfnation.jamfsoftware.com/featureRequest.html?id=45 Also look @ the jamf login hooks. JAMF MCX is refreshed @ every login & so once works the same as often.
I had already actually voted that one up! Hope it happens one day. I am already using login hooks to trigger other "non user" specific actions and preferences. Unfortunately due to how dmgs work its too complicated to deploy them to specific users (ie not using the user template)... hence why we turned to MCX which was designed for this sort of thing.
Thanks for the replies!
Anyone confirm if this is fixed in 8.7?
  • May 21, 2013
I don't think so. This defect was not mentioned in the release notes.
  • April 16, 2014
Sorry to revive this old thread... we are still seeing this issue with the latest version of Casper 8.
Just wondering if anyone is seeing this with Casper 9?
bentoms
  • April 16, 2014
Still the same in v9.
Please vote up the feature request I linked earlier, still under review since 11/15/11.
donmontalvo
  • April 25, 2014
@bentoms wrote:
The once setting works "sometimes" if all users do is logout then back in. So they change the setting, log out.. log in & it's still changed. But if they do a restart, the setting is often reapplied.. it's like the Mac on a restart contacts the JSS for the MCX settings.. then re-applies them.. :( But if they do a restart, the setting is often reapplied.. it's like the Mac on a restart contacts the JSS for the MCX settings.. then re-applies them.. :(
Hi Ben, I'm late to this thread, but just curious if this is an open JAMF issue? Regression? Before I open a ticket...
