Hello everyone,
I am experiencing issues with uninstalling Symantec Endpoint Protection 12.1.2 so that I can install version 12.1.4
I am trying to use the script that is mentioned in this thread: https://jamfnation.jamfsoftware.com/discussion.html?id=9271
I added "RemoveSymantecMacFiles" to Casper Admin and tried to run the script on a test computer with 12.1.2 installed. I get the following error:
Sending Wake On LAN command...
Opening SSH Connection to 128.135.xxx.xxx...
Authenticating...
Successfully authenticated.
Verifying Computer's Identity...
The MAC Address has been verified.
Checking Operating System Version...
Running Mac OS X 10.9.1 (13B4116)
Verifying /usr/sbin/jamf...
/usr/sbin/jamf is current (9.3)
Verifying /Library/Preferences/com.jamfsoftware.jamf.plist...
Preparing Policy...
Executing Policy 2014-10-10 at 11:19 AM | dkirk | 1 Computer...
Creating directory structure for /Library/Application Support/JAMF/Downloads/
Downloading http://128.135.xxx.xxx/Scripts/RemoveSymantecMacFiles.command...
Running script RemoveSymantecMacFiles.command...
Script exit code: 4
Script result: File: invalid option -- A
Usage: File [-bchikLNnprsvz0] [-e test] [-f namefile] [-F separator] [-m magicfiles] [-M magicfiles] file...
File -C -m magicfiles
Try `file --help' for more information.
ERROR: Invalid option or volume name: "Macloaner02".
Usage: RemoveSymantecMacFiles.command [-CcdeFfghIikLlmpQqRrV] [-QQ] [-re] [volume ...]
Submitting log to https://jss.uchicago.edu:8443/
Finished.
If I run the script locally on the target machine I experience zero issues. If anyone can assist I would appreciate it. I have about 50 Macs that I have to upgrade. Thanks!
