Connect to Server missing
  • June 9, 2015
  • 46 views
Hi All
Has anyone come across the "Connect to Server" disapprearing from the "Go" menu after installing JSS Casper v9.72
Best answer by Clean
Hi @Quan.nong,
do you have any configuration profiles with a Finder payload configured? The "Connect to Server" command is disabled by default in this payload, so make sure you check that box to enable it. Am I correct in assuming that this issue is occurring on your enrolled clients? Or are you having this issue within the actual server that is hosting your JSS?
  • June 9, 2015
Hi @Quan.nong,
  • June 9, 2015
Hi Chris
Thanks for the response. I do have a configuration profile for the "Finder" payload ( To show the HDD and Connected servers the desktop ) and you were correct that the command is disable, which I've now tick to enable.
Thanks very much for your help...much appreciated
