programatically add firewall exceptions?
  • May 18, 2011
  • 32 views
ImAMacGuy
Forum|alt.badge.img+23
Is there a way to add apps to the firewall via script or something?
Currently we are deploying a copy of the preference file during the
workflow, but for new apps coming out - we don't want to have to keep
redoing the firewall file.
John Wojda
Lead System Engineer, DEI & Mobility
3333 Beverly Rd. B2-338B
Hoffman Estates, IL 60179
Phone: (847)286-7855
Page: (224)532.3447
Team Lead DEI: Matt Beiriger
<mailto:mbeirig at searshc.com;jwojda at searshc.com?subject=John%20Wojda%20Fe
edback&body=I%20am%20contacting%20you%20regarding%20John%20Wojda.>
Team Lead Mobility: Chris
<mailto:cstaana at searshc.com;jwojda at searshc.com?subject=John%20Wojda%20Fe
edback&body=I%20am%20contacting%20you%20regarding%20John%20Wojda.> Sta
Ana
Mac Tip/Tricks/Self Service & Support
<http://bit.ly/gMa7TB>
RobertHammen
Forum|alt.badge.img+29
  • May 19, 2011
Nope. I resorted to the same approach that you did - stop/unload the firewall, push out the prefs, start/reload the firewall (and sometimes that errors out until the machine is restarted).
On May 18, 2011, at 2:27 PM, Wojda, John wrote:
I ran this past AppleCare Enterprise and was told it wasn't possible.
--Robert
  • May 19, 2011
You could turn off the Application-based firewall and use ipfw instead.
http://www.hanynet.com/waterroof/
This can be used to help you build a rule-list.
Ryan M. Manly
Glenbrook High Schools
  • May 19, 2011
We use ipfw instead of application firewall. IPFW is also more flexible in that you can craft your rules such that if you're on one set of IP scope (e.g. On your internal network) it's less restrictive than if you're on the outside world.
j
Jared F. Nichols
MIT Lincoln Laboratory
244 Wood Street
781.981.5436
