bug in Casper Admin v 7.01 with synchronizing
  • August 17, 2009
  • 12 views
Forum|alt.badge.img+31
I just noticed that when I want to synchronize my casper shares it now says replicate. However, in the older versions I used to be able to select several shares on the left hand nav bar and right click and say sync. Now, it seems that when I try to replicate anything Casper Admin becomes unresponsive, and I can no longer select multiple distribution points at once.
Anyone else experiencing this?
thanks
Tom
  • August 17, 2009
I have seen the same thing as I was trying to setup a replication sever this past Friday. I thought it might have been how I was setting things up, but this verifies that it wasn't. Casper Admin does become unresponsive and you have to quit/relaunch to be able to keep working with the program.
  • August 17, 2009
If you hit cmd + L it will go back into list mode and it will bypass
this. They are going to fix that soon. However, you can still only
replicate one server at a time now. I have an open ticket with jamf
support on the issue.
You can still just mount the share and copy stuff over AFP as well,
which I have done over the past.
  • August 17, 2009
We are experiencing the same issues with Casper Admin 7.01: you can only
replicate (sync) one distro point at a time and the Casper Admin becomes
unresponsive after replicating.
The work-around that JAMF provided was to type 'command' + 'L' to return
Casper Admin to a Show All view. This way you don't have to force quit the
application to proceed with your next task. (The Show All command is also
available under the 'File' menu.)
Jason
