Adobe Flash Player Critical Vulnerability CVE-2018-4878
  • February 4, 2018
  • 0 replies
  • 11 views
Hi Folks,
Thought I should share this. As most of you are probably already aware there is a nasty Flash Player vul out there, that can potentially give an attacker remote control over your system. Our CIO has gone the route of removing FlashPlayer from all computers till this has been completely addressed by Adobe, and browser developers. You can find details of the vul here.
Although I am aware of a script on JamfNation by @denmoff to remove Flash in this article, whoever, there was an issue with downloading the package and running it on computers with no user logged in.
This was the culprit:
sudo /Volumes/Flash Player/Adobe Flash Player Uninstaller.app/Contents/MacOS/Adobe Flash Player Install Manager -uninstall
_RegisterApplication(), FAILED TO establish the default connection to the WindowServer, _CGSDefaultConnection() is NULL.
This script will remove both PPAPI and NPAPI plugins, even while there are no users logged in and is completely silent. It was compiled using information can be found on this page.
# This script is meant for the purpose of removing the PPAPI and NPAPI Adobe FlashPlayer plugins
# This in response to an Adobe FlashPlayer critical vulnerability (CVE-2018-4878) which exists in
# Adobe Flash Player 28.0.0.137 and earlier versions.
# More details here: https://helpx.adobe.com/security/products/flash-player/apsa18-01.html
# The information used to compile this script can be found at:
# https://www.adobe.com/devnet/flashplayer/articles/flash_player_admin_guide.html
# [[USE AT YOUR OWN RISK]]
# Written by: Kamal Taynaz
# Senior Systems Engineer
# Carnegie Mellon University Qatar
# Set the Update to default values in mms.cfg
if [[ -e "/Library/Application Support/Macromedia/mms.cfg" ]]; then
  echo "`date` INF: mms.cfg was found"
  sleep 1
  echo "`date` INF: Eidting mms.cfg"
  sleep 1
  echo "`date` INF: Make AutoUpdateDisable = 0"
  sleep 1
  echo "AutoUpdateDisable=0" > "/Library/Application Support/Macromedia/mms.cfg"
  sleep 1
  echo "`date` INF: Make SilentAutoUpdateEnable = 0"
  sleep 1
  echo "SilentAutoUpdateEnable=0" >> "/Library/Application Support/Macromedia/mms.cfg"
  echo "`date` WAR: mms.cfg was not found"
  sleep 1
# Run launchctl unload tp unload the SAU daemon
echo "`date` INF: Looking for Launch Daemons"
sleep 1
daemon=$(launchctl list | grep adobe | awk '{print $3}')
if [[ "$daemon" =  "com.adobe.fpsaud" ]]; then
  echo "`date` INF: Launch Daemon $daemon was found"
  sleep 1
  echo "`date` INF: Unloading $daemon now"
  sleep 1
  launchctl unload "/Library/LaunchDaemons/com.adobe.fpsaud.plist"
  sleep 2
  if [[ $(launchctl list | grep adobe | awk '{print $3}') == "$daemon" ]]; then
    echo "`date` ERR: $daemon Launch Daemon failed to unload, please try again"
    exit 1
    echo "`date` INF: $daemon was unloaded successfully"
    sleep 1
# Delete the following if found
echo "`date` INF: Looking for Flash Player.plugin"
sleep 1
if [[ -e "/Library/Internet Plug-Ins/Flash Player.plugin" ]]; then
  echo "`date` INF: Flash Player.plugin found"
  sleep 1
  echo "`date` INF: Removing Flash Player.plugin"
  sleep 1
  rm -rf "/Library/Internet Plug-Ins/Flash Player.plugin"
    echo "`date` ERR: Flash Player.plugin Could not be removed. Please try again"
    exit 1
    echo "`date` INF: Flash Player.plugin was removed successfully"
    sleep 1
  echo "`date` WAR: Flash Player.plugin was not found"
  sleep 1
echo "`date` INF: Looking for flashplayer.xpt"
sleep 1
if [[ -e "/Library/Internet Plug-Ins/flashplayer.xpt" ]]; then
  echo "`date` INF: flashplayer.xpt found"
  sleep 1
  echo "`date` INF: Removing flashplayer.xpt"
  sleep 1
  rm -rf "/Library/Internet Plug-Ins/flashplayer.xpt"
    echo "`date` ERR: flashplayer.xpt Could not be removed. Please try again"
    exit 1
    echo "`date` INF: flashplayer.xpt was removed successfully"
    sleep 1
  echo "`date` WAR: flashplayer.xpt was not found"
  sleep 1
echo "`date` INF: Looking for PepperFlashPlayer.plugin"
if [[ -e "/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin" ]]; then
  echo "`date` INF: PepperFlashPlayer.plugin found"
  sleep 1
  echo "`date` INF: Removing PepperFlashPlayer.plugin"
  sleep 1
  rm -rf "/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin"
    echo "`date` ERR: PepperFlashPlayer.plugin Could not be removed. Please try again"
    exit 1
    echo "`date` INF: PepperFlashPlayer.plugin was removed successfully"
    sleep 1
  echo "`date` WAR: PepperFlashPlayer.plugin was not found"
  sleep 1
echo "`date` INF: Looking for manifest.json"
sleep 1
if [[ -e "/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json" ]]; then
  echo "`date` INF: manifest.json found"
  sleep 1
  echo "`date` INF: Removing manifest.json"
  sleep 1
  rm -rf "/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json"
    echo "`date` ERR: manifest.json Could not be removed. Please try again"
    exit 1
    echo "`date` INF: manifest.json was removed successfully"
    sleep 1
  echo "`date` WAR: manifest.json was not found"
  sleep 1
echo "`date` INF: Looking for com.adobe.fpsaud.plist"
sleep 1
if [[ -e "/Library/LaunchDaemons/com.adobe.fpsaud.plist" ]]; then
  echo "`date` INF: com.adobe.fpsaud.plist found"
  sleep 1
  echo "`date` INF: Removing com.adobe.fpsaud.plist"
  sleep 1
  rm -rf "/Library/LaunchDaemons/com.adobe.fpsaud.plist"
    echo "`date` ERR: com.adobe.fpsaud.plist Could not be removed. Please try again"
    exit 1
    echo "`date` INF: com.adobe.fpsaud.plist was removed successfully"
    sleep 1
  echo "`date` WAR: com.adobe.fpsaud.plist was not found"
  sleep 1
echo "`date` INF: Looking for FPSAUConfig.xml"
sleep 1
if [[ -e "Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml" ]]; then
  echo "`date` INF: FPSAUConfig.xml found"
  sleep 1
  echo "`date` INF: Removing FPSAUConfig.xml"
  sleep 1
  rm -rf "Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml"
    echo "`date` ERR: FPSAUConfig.xml Could not be removed. Please try again"
    exit 1
    echo "`date` INF: FPSAUConfig.xml was removed successfully"
    sleep 1
  echo "`date` WAR: FPSAUConfig.xml was not found"
  sleep 1
echo "`date` INF: Looking for fpsaud"
sleep 1
if [[ -e "/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud" ]]; then
  echo "`date` INF: fpsaud found"
  sleep 1
  echo "`date` INF: Removing fpsaud"
  sleep 1
  rm -rf "/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud"
    echo "`date` ERR: fpsaud Could not be removed. Please try again"
    exit 1
    echo "`date` INF: fpsaud was removed successfully"
    sleep 1
  echo "`date` WAR: fpsaud was not found"
  sleep 1
# Forget Package Receipt
echo "`date` INF: Search and remove FlashPlayer Receipts"
sleep 1
find /Library/Receipts -type f -name *FlashPlayer* -maxdepth 1 -exec rm -rf {} ;
pkgutil --packages | grep com.adobe.pkg.FlashPlayer >/dev/null
if [[ $? = 0 ]]; then
  echo "`date` INF: Forgetting com.adobe.pkg.FlashPlayer"
  sleep 1
  pkgutil --force --forget com.adobe.pkg.FlashPlayer >/dev/null 2>&1
elif [[ $? = 1 ]]; then
  echo "`date` WAR: com.adobe.pkg.FlashPlayer Receipt not found"
  sleep 1
# Remove The Flash Player PreferencePane
echo "`date` INF: Removing PreferencePane entry"
sleep 1
echo "`date` INF: Looking for Flash Player.prefPane"
sleep 1
if [[ -e "/Library/PreferencePanes/Flash Player.prefPane" ]]; then
  echo "`date` INF: Flash Player.prefPane found"
  sleep 1
  echo "`date` INF: Removing Flash Player.prefPane"
  sleep 1
  rm -rf "/Library/PreferencePanes/Flash Player.prefPane"
    echo "`date` ERR: Flash Player.prefPane Could not be removed. Please try again"
    exit 1
    echo "`date` INF: Flash Player.prefPane was removed successfully"
    sleep 1
  echo "`date` WAR: Flash Player.prefPane was not found"
  sleep 1
# Search user profiles ($p) for com.apple.systempreferences.plist and delete key
echo "`date` INF: Searing user profiles for plist"
for p in $(ls /Users); do
  if [[ -e "/Users/$p/Library/Preferences/com.apple.systempreferences.plist" ]]; then
    echo "`date` INF: Found com.apple.systempreferences.plist for user $p"
    sleep 1
    echo "`date` INF: Edit com.apple.systempreferences.plist for user $p"
    sleep 1
    defaults delete "/Users/$p/Library/Preferences/com.apple.systempreferences" "com.adobe.preferences.flashplayer" >/dev/null 2>&1
done
# Remove Flash Player Install Manager app
echo "`date` INF: Looking for Adobe Flash Player Install Manager.app"
sleep 1
if [[ -e "/Applications/Utilities/Adobe Flash Player Install Manager.app" ]]; then
  echo "`date` INF: Adobe Flash Player Install Manager.app found"
  sleep 1
  echo "`date` INF: Removing Adobe Flash Player Install Manager.app"
  sleep 1
  rm -rf "/Applications/Utilities/Adobe Flash Player Install Manager.app"
    echo "`date` ERR: Adobe Flash Player Install Manager.app Could not be removed. Please try again"
    exit 1
    echo "`date` INF: Adobe Flash Player Install Manager.app was removed successfully"
    sleep 1
  echo "`date` WAR: Adobe Flash Player Install Manager.app was not found"
  sleep 1
Hope you guys find it useful.
Regards,
Kamal
