Adding Printer via Self Service is causing CUPS to crash or not restart
  • January 10, 2014
  • 70 views
damienbarrett
Forum|alt.badge.img+19
For years, we have been having our end-users add printers via Self Service and it's worked flawlessly. Recently, we're seeing the following behavior:
1) End-user adds a printer(s)
2) CUPS is supposed to stop itself and then restart, but this doesn't seem to be happening.
3) The end-result is that no printers are listed in the "Print & Scan" system prefs pane.
A few notes;
- on a machine where this has occurred, when I try to restart CUPS at the command line using sudo launchctl start org.cups.cupsd but it does not actually start CUPS again. I know this because browsing to http://localhost:631 on the machine returns errors like "Cannot connect to server"
- a restart of the system actually gets CUPS running again and the just-added printers show up, but we don't feel it's acceptable to ask our end-users to have to restart their system just for adding a printer.
This *used* to work just fine all the way through Casper 7.x to Casper 9.2.1. The only thing's that has changed recently is an update to JSS 9.22. I don't know if this is what has introduced this problem.
Any ideas? I've kind of run out of things to try at this point.
Best answer by Louise
Hey All! Happy Friday! It looks like we are running into a known issue with 9.22. The good news is there is a really simple workaround. Check out this thread for more info:
https://jamfnation.jamfsoftware.com/discussion.html?id=9373#responseChild51511
  • January 10, 2014
I have also noticed this since updating to JSS 9.22. No solution on our end yet.
  • Employee
  • January 10, 2014
damienbarrett
  • January 10, 2014
Ah ha! I totally missed this post on the boards. Weird that it didn't show up in my searches...
I've written a simple script to bounce CUPS and have attached it to my printer policies and this is a sufficient workaround for now. Thanks!
