open Self Service via email link
  • January 10, 2014
  • 22 replies
  • 83 views
Forum|alt.badge.img+21
forgive me if im going mad but im sure someone told me there was a trick to send a link via email which ill open the Self Service.app on the machine.
Does anyone know of this?
Best answer by rich.trouton
We've been using this link and it's worked well for us:
selfservice://localhost
Forum|alt.badge.img+33
  • January 10, 2014
  • January 10, 2014
@rtrouton thanks very much
ive been looking at this FR https://jamfnation.jamfsoftware.com/featureRequest.html?id=395
i managed to get mine working by
1.open Self Service and in the Run / Install button drag it to the desktop
2.opened terminal and dragged the Run.inetloc in to terminal
  1. In terminal it then showed selfservice://product=XXXX
4.I then opened my email client and included a hyperlink
  1. Sent an email to myself and Self Service then runs the policy :)
mpermann
Forum|alt.badge.img+22
  • January 10, 2014
This is a neat trick! Does anyone know how to make it work using the web interface in Gmail? It works great from Apple Mail but no dice in Gmail's web interface.
scottb
  • January 13, 2014
Great tip on the URL. Using 8.7.3 and we have users login to Self Service with their AD credentials. Problem is that with this config, the URL opens Self Service and then it crashes.
If Self Service is already open, it works without crashing. If this is a supported method, I should file a bug with JAMF.
  • January 13, 2014
Works fine on 9.22 with no login required for Self Service
scottb
  • January 13, 2014
I don't suppose you could change the requirement to test on 9.22 for the login piece?
Probably not worth filing a bug for 8.x any longer…
  • January 13, 2014
The behaviour boettchs is describing is exactly the same for me in 9.22. Self Service crashes if users are required to log in when clicking the link.
This is a very nice feature however and I can definitely see its potential in a support context. It would be nice if it could tie in with Notification Centre, like other apps do.
scottb
  • January 13, 2014
@yan1212: Good idea on NC. It would be nice to have this for new packages without having to use email (which likely get ignored anyway). Wondering - can that sort of thing be a persistent or a recurring notice?
  • January 14, 2014
@yan1212][/url Thats a great idea if it could tie in with NC. Feature request??? I would.. but i've trodden on a few toes lately :(
  • January 14, 2014
Just submitted this as a feature request.
https://jamfnation.jamfsoftware.com/featureRequest.html?id=1832
  • June 13, 2014
The email link works well on JSS 9.30 with Self Service not requiring login:
The behavior that I have seen when opening the application up via selfservice://localhost
If the application is closed, it will open up the application.
If the application is open, but the window is closed, it only brings up the application to the forefront (it does not re-open the window).
Behavior that I have seen when opening up a policy via selfservice://product=xxxx
If the application is closed, it will open up the application AND run the policy automatically (even if I have Self Service configured to ensure that the user views the description).
If the application is open, but the window is closed, it only brings up the application to the forefront (it does not re-open the window); the policy automatically runs (even if I have Self Service configured to ensure that the user views the description).
  • February 22, 2016
I would like to be able to launch Self Service from a link on our company intranet.
I tried putting selfservice://localhost in Safari and i'm getting prompted to "Choose Application", after I manually choose "Self Service" it seems to work.
I guess I need a script to register selfservice with Safari on all my Macs? Anyone else doing something similar?
apizz
Forum|alt.badge.img+15
  • February 22, 2016
@mackin_j If I manually enter the address in either Safari or Chrome it doesn't work for me. But if I click on a hyperlink in an email pointing to selfservice://localhost from an email it works.
Haven't tried embedding in a page though. [Self Service Test](selfservice://localhost)
apizz
  • February 23, 2016
^^ my link above works for opening Self Service for me as well.
dpertschi
Forum|alt.badge.img+19
  • February 23, 2016
don't think you need the word localhost in the hyperlink.
@emilykausalik posted about this not long ago and it's been working for me quite well as just selfservice://
  • February 25, 2016
Thanks for the responses.
After further testing, I found that selfservice://localhost does not work in Safari if Self Service hasn't been launched at least once. I am getting the following message:
Any ideas on how to fix this without having to launch Self Service manually on all of my Macs?
  • February 25, 2016
You could script the opening of Self Service...
open /Applications/Self Service.app
  • February 23, 2022
dvasquez
  • August 3, 2022
I know it's almost 6 years later but this page might be helpful:
https://docs.jamf.com/10.28.0/jamf-pro/administrator-guide/Jamf_Self_Service_for_macOS_URL_Schemes.html
I know this is old. And maybe this has been answered but is there a way/method to add a self-service policy link in a google doc?  I tried this: jamfselfservice://content?entity=policy&id=xxx&action=execute
But it will not save.
Thank you all.
  • August 3, 2022
wow this thread is still going?
charliwest
  • September 1, 2022
Thank you all.
Is there a "hyperlink" function in google docs? You would just edit it there and add the hyperlink and you can also then change the text to say something else if you wanted
dvasquez
  • September 1, 2022
Our issue was that our google docs are tied to an organization and not externally assessable to all or everyone.
So I am good now.
