Uninstall Shockwave script?
  • October 6, 2015
  • 33 views
Mhomar
Hi Everyone! Does anyone have a script that will "uninstall" all versions of Shockwave 12 completely from my Macs?
Best answer by cvgs
Try this. No guarantees, though.
It also is more complicated than it needs to be, but i just copy and paste a skeleton script for those purposes.
# Uninstalls all files and processes
# Define your removal options here
launchdaemons_to_remove=(
launchdaemons_to_remove_at_end=(
launchagents_to_remove=(
directory_trees_to_remove=(
"/Library/Application Support/Adobe/Shockwave 11"
"/Library/Application Support/Adobe/Shockwave 12/DirectorShockwave.bundle"
"/Library/Application Support/Adobe/Shockwave 12/Xtras"
"/Library/Internet Plug-Ins/DirectorShockwave.plugin"
empty_directories_to_remove=(
"/Library/Application Support/Adobe/Shockwave 12"
"/Library/Application Support/Adobe"
pkg_receipts_to_remove=(
"com.adobe.shockwave"
"adobe.adobeShockwavePlayer.shockwave11.pkg"
"adobe.adobeShockwavePlayer.shockwave12.pkg"
casper_receipts_pattern='^Shockwave_Installer_Full_.*.[m]?pkg$'
function RemovePrefFiles () {
    # custom pref removal function
    return 0
# NOTHING TO CHANGE BELOW HERE
# get script parameters
targetDrive="${1}"
computerName="${2}"
userName="${3}"
bRemovePrefs="${4}"
# Variables
CASPER_RECEIPT_PATH="${targetDrive}/Library/Application Support/JAMF/Receipts"
# check script parameters
if [[ "${targetDrive}" == "" ]]; then
    echo "No Target Drive set."
    exit 1
# check if we also should clear the preferences
if [[ "${bRemovePrefs}" != "yes" ]]; then
    bRemovePrefs=""
# get the first non-root loginwindow user
# TODO: get all users and and unload agents for all of them
current_user=$( ps aux|grep "loginwindow [c]onsole"|grep -v "^root"|head -n 1|awk '{print $1}' )
if [[ "${current_user}" == "" ]]; then
    current_user_loginpid=""
    echo "Could not determine current Aqua user - not loading any LaunchAgents"
    current_user_loginpid=$( ps ax -U "${current_user}"|grep "loginwindow [c]onsole"|head -n 1|awk '{print $1}' )
    echo "Current Aqua user is ${current_user}, loginwindow pid is ${current_user_loginpid}"
# remove LaunchDaemons
for item in "${launchdaemons_to_remove[@]}"; do
    fs_item="${targetDrive}/Library/LaunchDaemons/${item}.plist"
    if [[ "${targetDrive}" == "/" ]]; then
        launchdRunning=$( launchctl list 2>&1 |
            /usr/bin/grep -c "^.*[[:space:]]${item}$" 2>/dev/null )
        if [[ ${launchdRunning} -gt 0 ]]; then
            launchctl remove "${item}"
                && echo "Removed active LaunchDaemon ${item}"
                || echo "Error removing active LaunchDaemon ${item}"
    if [[ -e "${fs_item}" ]]; then
        rm -f "${fs_item}"
            && echo "Removed ${fs_item}"
            ||  echo "Error removing ${fs_item}"
done
# remove LaunchAgents
for item in "${launchagents_to_remove[@]}"; do
    fs_item="${targetDrive}/Library/LaunchAgents/${item}.plist"
    if [[ "${targetDrive}" == "/" && ${current_user_loginpid} -gt 0 ]]; then
        launchdRunning=$(
            launchctl bsexec "${current_user_loginpid}" chroot -u "${current_user}" /
            launchctl bsexec "${current_user_loginpid}" chroot -u "${current_user}" / launchctl remove "${item}"
                && echo "Removed active LaunchAgent ${item} for user $current_user"
                || echo "Error removing active LaunchAgent ${item} for user $current_user"
        rm -f "${fs_item}"
done
# remove directories
for item in "${directory_trees_to_remove[@]}"; do
    fs_item="${targetDrive}/${item}"
    if [[ -d "${fs_item}" ]]; then
        rm -r "${fs_item}"
done
# remove empty directories
for item in "${empty_directories_to_remove[@]}"; do
        rmdir "${fs_item}" 2>/dev/null
            && echo "Removed empty directory ${fs_item}"
done
# remove receipts
for item in "${pkg_receipts_to_remove[@]}"; do
    /usr/sbin/pkgutil --volume "${targetDrive}" --forget "${item}" 2>/dev/null
done
# remove casper receipts (empty files in CASPER_RECEIPT_PATH)
IFS=$'
if [[ "${casper_receipts_pattern}" != "" ]]; then
    casper_receipts=(
    $( /bin/ls "${CASPER_RECEIPT_PATH}" 2>/dev/null |
        /usr/bin/grep "${casper_receipts_pattern}" )
    for item in "${casper_receipts[@]}"; do
        if [[ -f "${CASPER_RECEIPT_PATH}/${item}" ]]; then
            /bin/rm "${CASPER_RECEIPT_PATH}/${item}"
                && echo  "Removed ${CASPER_RECEIPT_PATH}/${item}"
                || echo  "Error removing ${CASPER_RECEIPT_PATH}/${item}"
    done
    IFS=$OLDIFS
# remove preferences
if [[ "${bRemovePrefs}" == "yes" ]]; then
    echo "Removing preferences"
    RemovePrefFiles
# remove final LaunchDaemons
for item in "${launchdaemons_to_remove_at_end[@]}"; do
                && echo "Removed active final LaunchDaemon ${item}"
                || echo "Error removing active final LaunchDaemon ${item}"
        rm -f "${fs_item}"
done
  • October 6, 2015
    return 0
targetDrive="${1}"
computerName="${2}"
userName="${3}"
bRemovePrefs="${4}"
# Variables
    exit 1
    bRemovePrefs=""
        rm -f "${fs_item}"
done
        launchdRunning=$(
        rm -f "${fs_item}"
done
        rm -r "${fs_item}"
done
done
# remove receipts
done
IFS=$'
    casper_receipts=(
    done
    IFS=$OLDIFS
    RemovePrefFiles
        rm -f "${fs_item}"
done
Mhomar
  • October 6, 2015
@cvgs First several "Wow's". Wow 1= Super fast accurate response... THANKS Wow 2= Awesome script! I had to bring my Code guru (Jon) over just to help me wrap my head around it. I can see using this as a template in the future. So again thanks! I/we did make just a few changes to get it to perform as we expected.
