Hi guys,
Just wondering if anyone else is using Patchoo. I am playing around with it in our environment, and I have it working and deploying updates.
The only thing it doesn't seem to be doing is presenting the package names its downloaded in the cocoa dialog prompt screen. I've read the documentation and understand that it should pull information from the info on the package, and if thats blank it should just pull the filename barring the extension.
I have tried this with several packages but all seem to not display the name at all, its just blank. Am I missing something obvious?
