I'm in the planning phase for using Casper to upgrade 800 machines to 10.9.x. Half of these are 10.6.8.
Those of you that have gone down this rabbit hole already, can you comment on any unexpected results on the older machines and or other pre-planning concerns?
I'm mostly unsure with print drivers and printer configs. Will I potentially have to install new drivers and configs for all MFP's we use, or will I luck out and they'll just continue to work?
Application incompatibility from 10.6.8, can't wait for the users to tell me what doesn't work after upgrade. The only option that comes to mind is to pull application usage logs and manually scan through for things that are being used frequently and research the version/OS compatibility.
No FileVault here to worry about, and yes we will pilot/test with maybe 50 machines in a variety of locations.
