Hey Everyone,
Not sure what version this happened on, but we thought to do a test on new enrollments and since 2.4.5 on the part where a user logs into azure and then asks to enter their network password. We get an "Invalid Request". We we're on 2.2.2 before this.
Some have suggested to change this to true.
"Create a Separate Local Password
If set to true, this key prompts users to create a new password for their new local account. If set to false, this key prompts users to re-enter their network password, which also becomes the local account password. This ensures a user's network and local password are synced during user creation."
We don't want to do this as it creates confusion when it's time to reset the password back to Azure. Unless something changed, Jamf connect cannot write back directly to Azure. We've been needing to go through the SPR.
