What do your policy logs tell you?
Need some more information to trouble shoot.
What do the policy logs say for the computer you are attempting to install the policy on?
You can find this information by navigating to your Jamf Pro Dashboard in a browser -> Computers -> Search Inventory -> Computer -> History -> Policy Logs -> Show (Next to the Policy Name you are installing)
It will provide you some information as to what happened if successful & if not. This way you can drill down to the root of the problem
example of a policy that installs a package for google chrome
I know for sure that the distribution point is mounted cause I can add these pkgs to Jamf Admin.
@typtran1 That's not what the logs say.
Am I looking in the wrong place?
This has happened to us a few times. I literally remap everything
The following is what I have done to resolve.
confirm your Share Repo is in the right spot on your JSS Server, also, right click & get info / check sharing permissions
Check Read Writes Accounts on your JSS Web interface, Make sure they match the Servers R/W Accounts.
Go to JSS Server
- System Prefs -> Sharing -> File Sharing -> SharedRepoFolder
---- Remove it
- Go to R/W users and reset the password
Add share back to File sharing & add the users again
On JSS Web interface (Settings->ServerInfrastructure->File Share Distribution Points)
- Make sure Server url is correct & set to Master Distribution Point
- Add the users and new password again
- Make sure share name is correct, AFP, Port 548 (SMB is blocked by every firewall)
-- Double Check Everything
-- Boot server
if all else fails, make a totally new file share distribution point on your JSS Web interface & remap everything on the server & web interface again. (again make sure to set as master distribution point)
IF THAT FAILS - make a jamf support ticket haha
