jAMF Connect and MFA (Azure AD) - No Prompt for MFA
  • April 14, 2022
  • 14 views
dpwlg
Hope someone can help me out here. I have been tasked to switch our laptops to be signed in with our Azure AD accounts to the local machines which connect to the user's local account. In order to tackle this was able to set up jAMF connect with no issues and can successfully login to my test machines.
The only issue is that once I sign in with Azure credentials I am not prompted with MFA to verify myself.
Currently, all our Windows users have to verify themself via MFA when logging in.
dwynn
  • April 19, 2022
I had this same issue. You have to enable MFA on the account they are logging in with. So for us, I had to enable MFA on a custom attribute in Exchange.
AntonyaJ
  • April 22, 2022
Are you saying that it's allowing your users to login without MFA, or the MFA screen never shows?
