Google Cloud Identity Provider Configuration
  • April 22, 2022
  • 36 views
has anyone seen this error when configuring the google cloud ldap integration
"Cannot verify cloud identify provider domain name"
My keystone is showing as accepted and populated but I cannot save the config due to this error.
Using LDAPS as the connection type.
1 reply
I'm seeing this error now!
