Unable to use Change password option in Jamf Connect Menu App
  • June 7, 2022
  • 4 replies
  • 69 views
When trying to use Change password option within Jamf Connect Menu App, the following message comes up, Configuration file does not specify default realm. The realm is configured in the Configuration Policy for Jamf Connect, but it seems it's not able to read it.
Best answer by ilya25
Hello,
The Jamf Connect Log can be gathered to a file on the Desktop, and should be able to confirm whether Jamf Connect is reading the correct realm from the preference key:
log show --st:le compact --predicate 'subsystem == "com.jamf.connect"' --debug > ~/Desktop/JamfConnect.log
 Might also be worth creating a krb5.conf file as described in the solution here: https://community.jamf.com/t5/jamf-pro/kerberos-sso-default-realm-issue/m-p/236344/highlight/true#M224163
Hope this helps!
Thanks. Was able to figure it out by adjusting password complexity policy related to characters.
ejadadic
  • June 8, 2022
What Idp are you using?
  • June 9, 2022
on-prem
  • June 15, 2022
Hello,
Hope this helps!
  • June 16, 2022
Hello,
Hope this helps!
