We are currently implementing Jamf Connect Login + Sync for Okta in my org.
As I understand it, MFA needs to be set up on the workplace level, so at domain-admin.okta.com/admin/access/policies. If I set this, this will override the MFA settings for my default policy.
If I wanted to deny MFA if they are within our network range, but keep it on for everything else, does this mean I have to individually set a prompt-for-factor policy on every app we have in Okta? Would there be a potential pitfall in this scenario?
Conversely, is there a way to get rid of the prompt-for-factor requirement when in the network zone on my Jamf Connect OIDC apps themselves? I attempted changing this from the Sign On Policy level but it does not seem to do anything.
Hey, we are running into the same issue with Jamf connect and Okta. Did you ever get a solution working?
Hey, same here...any idea how to solve this?
