@Hiller , Jamf Connect isn't the end all be all. It really just keeps the local password and the Idp password in sync when a password reset/change is required, (It also keeps keychains in sync, which is nice) It's up to the user to remember their password (even on a Windows machine). If this does happen you have two options:
Method 1
1. Disable jamf connect login with a check-in/startup policy.
2. Reboot the machine.
3. Reset the local password with the recovery key at the FV2 login screen.
4. Reset the IDP password.
5. log into the computer with the new FV2 password.
6. Sync the FV2 and IDP password.
Method 2
1. Boot to Recovery
2. Reset the password with the recovery key.
3. Reset the IDP password.
4. Reboot.
5. Use the FV2 password to bypass the FV2 login.
6. Use the IDP password to login/sync both passwords.
Not really jamf's fault but Apple's fault.
If you want to reduce the number of logins enable passthrough authentication btw.
Been working with Jamf Connect since 2020 (deep in the quarantine). Deployed and managed it without ever touching a user's machine. (500+ fleet all remote and global) It's honestly resolved most of my password reset problems, just takes some time to understand.
Should see improvements with jamf connect and platform sso in ventura.
Method 1
Method 2
1. Boot to Recovery
4. Reboot.
Also, if you want to save money on JC, you can use the free version named XCreds. Just listened to the episode on the macadmins podcast. the creator of Jamf Connect is "involved" with it's creation as well. May switch to it to save some money.
Method 1
Method 2
1. Boot to Recovery
4. Reboot.
Well, that's promising. I was about ready to throw this out the window.
But... I'll try to get my process down and see if I can do it in a reasonable way.
Good luck man, you may also want to join #MacAdmins on slack to interact with the Jamf Connect engineers directly. They're in #jamfconnect.
Does XCreds require LDAP to sync that password like with Jamf Connect? I'm looking through the product description but not finding an answer. Thanks!
