Double Login with Jamf Connect
  • March 11, 2019
  • 8 replies
  • 49 views
I installed Jamf Connect on my mac and now I have to log in twice: once with the Azure AD account, and again with the local account password. Any thoughts on this?
  • March 21, 2019
Is FileVault enabled?
  • March 21, 2019
which jamf connect version? Jamf Connect Login with Azure?
  • March 22, 2019
I'm getting the same Jamf Connect Login Azure.
Login at azure window, login at JAMF connect window.
Why do I have the second login?
  • March 26, 2019
Yes, according to support this is by design and a feature request has been put in to get it into one login.
  • April 10, 2019
  • August 8, 2019
Please, we need only 1 login. What is the purpose of having 2? Everyone is complaining. Please address this. Thank you.
  • Employee
  • October 14, 2021
With the release of Jamf Connect 2.6.0 Beta 1, we are now testing out a solution to skip the extra "verify" step in Jamf Connect Login when using Azure Active Directory. If you are interested in joining this beta feature, please navigate to the Jamf Account page and click on Product Feedback to enroll in the Jamf Connect 2.6.0 beta. We would appreciate your feedback as we ready this change.
  • October 15, 2021
@david_engum
I was just thinking about this yesterday and wondering when we would see this since 2.5 is out with similar for google. 👍
