Jamf Connect Deployment and Update Settings
  • May 10, 2023
  • 56 views
danlaw777
Trying to figure out the update process. I'd like to keep my macs up to date with the latest versions, especially when i see the notes identifying an issue I'm having. The problem is, I can't see how to scope an individual machine, or several machines, to test the latest update. Is that even possible?
MikePh
  • Employee
  • May 13, 2023
If you’d like to test the latest update, the best way would be to use a policy and scope it out to your test computer. Once you’ve verified you’re okay with it, then you can have the Jamf Connect Update (Settings -> Jamf Apps -> Jamf Connect) set to manual. This way you can specify which version is pushed out without going passed it until you change it after you’ve tested out a new version.
danlaw777
  • May 15, 2023
i know the work around steps, that part is obvious. my question was how to use the auto update portion with a small amount of testers to  test as opposed to making yet another policy when i should be able to use whats already there.
  • May 18, 2023
In the past, I deployed updates as a policy since it silently installs the new files and takes effect when the app is restarted (usually computer restart.) Never had issues that way. I personally wouldn't trust auto updates for Jamf Connect, seeing as how many other issues we have with it.
