High Sierra Imaging: How-To
  • February 2, 2018
  • 40 replies
  • 130 views
chrisdaggett
First: This is not Apple approved. I know that, you know that, do it at your own risk. I do, this works fine.
UPDATE: I have added my imager for download to the bottom of this post with instructions
This is not a discussion about why or opinions :). Some of us have this need, this is a solution!
Thought I would share as I have seen a number of folks looking for these answers. Some of you are just looking for a certain piece of this, and thats great. Some of you are looking for a way to make an imager and that is here too. If you want to take the whole thing and make a fully automated USB Imager than that is also here :). If you don't like imaging, don't want to use this, or don't like it. That is okay! We each have our own thoughts and way of doing things, this isn't for you :).
If you are interested, dabble in this, or have other thoughts/ways to make it better PLEASE post and share below!
APFS / High Sierra Imaging: (Steps 1 and 3 are assuming your machines have never been on 10.13 and are missing the new firmware. If they are already upgraded you can skip Step 1 and 3)
STEP 1: Make a Firmware update Package for/from the device you want to deploy:
From the type of device you want to deploy to, have full High Sierra install App in application folder and run: (doesn't have to be from a 10.13 machine)
# Based on investigations and work by Pepijn Bruienne
# Expects a single /Applications/Install macOS High Sierra*.app on disk
IDENTIFIER="com.foo.FirmwareUpdateStandalone"
VERSION=1.0
# find the Install macOS High Sierra.app and mount the embedded InstallESD disk image
echo "Mounting High Sierra ESD disk image..."
/usr/bin/hdiutil mount /Applications/Install macOS High Sierra*.app/Contents/SharedSupport/InstallESD.dmg
# expand the FirmwareUpdate.pkg so we can copy resources from it
echo "Expanding FirmwareUpdate.pkg"
/usr/sbin/pkgutil --expand /Volumes/InstallESD/Packages/FirmwareUpdate.pkg /tmp/FirmwareUpdate
# we don't need the disk image any more
echo "Ejecting disk image..."
/usr/bin/hdiutil eject /Volumes/InstallESD
# make a place to stage our pkg resources
/bin/mkdir -p /tmp/FirmwareUpdateStandalone/scripts
# copy the needed resources
echo "Copying package resources..."
/bin/cp /tmp/FirmwareUpdate/Scripts/postinstall_actions/update /tmp/FirmwareUpdateStandalone/scripts/postinstall
# add an exit 0 at the end of the script
echo "" >> /tmp/FirmwareUpdateStandalone/scripts/postinstall
echo "exit 0" >> /tmp/FirmwareUpdateStandalone/scripts/postinstall
/bin/cp -R /tmp/FirmwareUpdate/Scripts/Tools /tmp/FirmwareUpdateStandalone/scripts/
# build the package
echo "Building standalone package..."
/usr/bin/pkgbuild --nopayload --scripts /tmp/FirmwareUpdateStandalone/scripts --identifier "$IDENTIFIER" --version "$VERSION" /tmp/FirmwareUpdateStandalone/FirmwareUpdateStandalone.pkg
# clean up
/bin/rm -r /tmp/FirmwareUpdate
/bin/rm -r /tmp/FirmwareUpdateStandalone/scripts
Firmware package will be located at:
AGAIN THAT IS DEVICE SPECIFIC
(supposedly, I haven't tested it and don't plan to for obvious reasons)
Step 2: Making an AFPS Image:
Have a good 10.13 master machine. in Disk utility resize partition to smallest size if you want to have an image that isn't the entire size of the hard drive (It will expand on restore)
Apple has made this no longer work. Instead use terminal to resize the Container.
diskutil apfs resize Container disk2s2 30g
(change disk2s2 to the partition of the container you want to shrink and 30g to whatever size you can shrink to)
Target disk Master to another machine or use USB drive.
In Disk Utility (must be High Sierra UPDATE: Must be 10.13.3 or Lower. Apple botched something in 10.13.4+ for capturing a container image) - View - Show all devices
Unmount APFS Volume under Container of drive you want to make image
File - New image - from Container (DO NOT COMPRESS)
Don't forget to scan image for restore
Other Random Details:
You Will not see any volumes when Alt-Booting etc.. until Firmware is updated, APFS volumes will not show at all.
After running Firmware package, firmware updates on next boot (Typical apple loading slider), then reboots into startup disk
You can update firmware on a 10.12 machine and 10.12 will still boot fine.
STEP 3: Making an Imager USB without APFS: (super important if you want to boot to your "imager" on a machine that does not yet have the firmware!)
Need a machine with SIP Disabled
(boot to recovery / MacOS install USB and in terminal: "csrutil disable" , then reboot)
Boot to good OS of SIP Disabled machine (doesn't have to be 10.13) and download High Sierra installer App / copy from USB to Applications folder.
From terminal Run:
/Applications/Install macOS High Sierra.app/Contents/Resources/startosinstall --converttoapfs NO --volume /Volumes/DestinationDriveName
STEP 4: IMAGING!
Either make sure you run the Firmware package on the machine before you image it (you can install at in 10.12 before you image it), or use a USB drive to boot to a good OS (again doesn't have to be 10.13) and run the firmware package you made originally .
First Manually:
From Disk Utility on 10.13 machine/usb - erase drive to APFS
Unmount Volume Under Container
Click on Container and choose restore and Choose image made originally
SCRIPT:
Here is the script I use from a USB Drive. Fully automated. Drive does not have to be prepped in any way script will erase the entire drive and make it APFS with correct containers from Image and upgrade the firmware, as well as set startup disk. It also copies a FirstBoot script to enroll using QuickAdd. (Uses Applescript to set startup disk VIA System Preferences. No longer able to set startup disk via Bless or systemsetup due to SIP)
If you want it to be truly automated, you need to run the script as the root user. Otherwise there is user interaction. (To Enable Root: Directory Utility - unlock button - Edit in menu - Enable Root). With High Sierra you can no longer set Root as auto login in OSX. If, like me, you want the USB fully automated you can set root as auto login with the following:
sudo defaults write /Library/Preferences/com.apple.loginwindow autoLoginUser root
sudo defaults write /Library/Preferences/com.apple.loginwindow autoLoginUserUID 0
Script assumes that A.) you have the image you want to use in /Configurations B.) The Firmware is in /Packages C.) In order for startup disk via Applescript to work you must put Terminal in Security - Privacy - Accessibility on your "imager", and you must be Root user (otherwise you would have to unlock the preference pane) - OPTIONAL D.) If you want to have it enroll on firstboot you must put quickadd.pkg in /Data
sleep 2
#   Restore AFPS Image to internal container from /Configurations
asr restore -s /Configurations/*.dmg -t /dev/disk0s2 -erase -noverify -noprompt
#   Install Firmware package from /Packages IF needed
current_efi_version=$(/usr/libexec/efiupdater | grep "Raw" | cut -d ':' -f2 | sed 's/ //')
echo "current_efi_version $current_efi_version"
latest_efi_version=$(ls -La /usr/libexec/firmwarecheckers/eficheck/EFIAllowListShipping.bundle/allowlists/ | grep "$current_efi_version")
echo "latest_efi_version $latest_efi_version"
if [ "$latest_efi_version" == "" ]; then
echo "EFI Outdated"
installer -pkg /Packages/*.pkg -target / -allowUntrusted
else echo "EFI Current"
#mount Volume - MUST CHANGE VOLUME NAME TO NAME OF YOUR IMAGE
Diskutil mount "VOLUMENAME"
Sleep 2
#Copy Firstboot Files so that machine Automatically Enrolls on First Boot - MUST CHANGE VOLUME NAME TO VOLUME NAME OF YOUR IMAGE
cp /Volumes/Imager18/Data/com.imager.firstboot.plist /Volumes/VOLUMENAME/Library/LaunchDaemons/
mkdir /Volumes/VOLUMENAME/usr/local/data
cp /Volumes/Imager18/Data/firstboot.sh /Volumes/VOLUMENAME/usr/local/data/
cp /Volumes/Imager18/Data/quickadd.pkg /Volumes/VOLUMENAME/usr/local/data/
chmod 644 /Volumes/VOLUMENAME/Library/LaunchDaemons/com.imager.firstboot.plist
chmod 777 /Volumes/VOLUMENAME/usr/local/data/firstboot.sh
chmod +x /Volumes/VOLUMENAME/usr/local/data/firstboot.sh
#Set Startup disk using AppleScript
#Requires Terminal in Security - Privacy - Accessibility
#DO NOT TOUCH MACHINE WHILE THIS IS HAPPENING
osascript -e 'tell app "System Preferences" to Activate'
Sleep 2
osascript -e 'tell app "System Preferences" to set current pane to pane id "com.apple.preference.startupdisk"'
Sleep 3
osascript -e 'tell app "System Events" to tell process "System Preferences" to click radio button 2 of radio group 1 of scroll area 1 of group 1 of splitter group 1 of window 1'
osascript -e 'tell application "System Events" to tell process "System Preferences" to click button 1 of window "Startup Disk"'
Sleep 1
osascript -e 'tell app "System Events" to tell process "System Preferences" to set frontmost to true'
Sleep 2
osascript -e 'tell app "System Events" to keystroke return'
Fully Automated Checklist:
1.) USB Drive with HFS+ High Sierra Installed (NOT APFS)
2.) Root Enabled
3.) Root set to Autologin
4.) Script set to run on Login (Easiest way is just drag it in to login items)
5.) APFS Image in /Configurations
6.) Firmware Package in /Packages
7.) Optional: quickadd.pkg in /Data
Congratulations you have a USB that you will boot to and 4-5 minutes later when it is done you will have a freshly imaged machine on 10.13 with the correct Firmware and APFS!
MY IMAGER: https://tinyurl.com/APFSimager
LINK FIXED
To use: Download DMG and restore to USB Thumb drive.
Place Firmware package in /Packages
Place quickadd.pkg in /Data
Place APFS Container image in /Configurations
If you do not want to use Quickadd portion of imager simply delete the /Data folder.
Best answer by cruncx
Thanks for this
can you upload your image again
chrisdaggett
  • February 5, 2018
Updated so it does not care about image name or package name for simplicity and fix Setting startup disk. **(Setting startup disk no longer works via scripting using bless or systemsetup due to SIP. Workaround created using Applescript. Requires Terminal is in Security - Privacy - Accessibility on imager)
  • February 6, 2018
Hi Chris, how do you handle non SSD (Fusion, Spinning disks etc) based macs as APFS is only supported on SSDs. Would you not be better of doing an in place upgrade in an Apple supported fashion to get to 10.13. Then you can reimage directly to 10.13 as needed.
Or just creating a bootable USB installer.
With /Applications/Install macOS High Sierra.app/Contents/Resources/createinstallmedia
chrisdaggett
  • February 6, 2018
@a.stonham The only Apple computers we have that are non-ssd are 2009 White macbooks, those are 100% imaged (and can't take 10.13 anyway).
If I were to image HFS+ 10.13 I would use a 10.11 USB Imager (pre-SIP) this allows you to things like use bless for setting startup disk. (what I did previous to 10.13 / HS) and works perfectly fine for imaging HFS partitions anyway. You wouldn't have to deal with APFS or containers, or the firmware as that only applies to APFS.
Doing an in-place upgrade is a ludicrous amount of time when you are talking 950 machines for one building :).
georgecm12
  • February 6, 2018
Very interesting. While admittedly frowned on by Apple, they really haven't given any good alternatives at this time for large volume lab/classroom deployments, so this may help get us by until they do. I'll have to give this a try in our tech lab.
  • February 10, 2018
For the different device firmware packages, has anyone been able to determine how specific they are in regards to the hardware? Meaning is the firmware package the same across each Model Identifier, or can it vary amongst the same Model Identifier depending on the components that are used like brand or size of SSD drive, etc?
chrisdaggett
  • February 28, 2018
@scottlep In my testing it has not made a difference regarding size or brand of SSD, only SSD vs Fusion vs Mechanical. (since mechanical and Fusion drives do not support AFP and do not require the firmware update)
  • February 28, 2018
Hi nation, We are setting this up for someone that wanted one solution for thin and re-image to High Sierra, Working with gregnagle's bootstrappr, we modified the script to support re-imaging and thin imaging. This is all done from recovery mode. For re-imaging we are restoring 10.13 hfs dmg created with autodmg(w/localadmin and 1st boot pkg) via http, entering in the device name and rebooting. For thin imaging, use bootstrappr as per original documentation. restores are taking between 4/6 mins. We are right now in the process of testing APFS, will update post once we are done.This is working well until Apple releases the promised changes
chrisdaggett
  • February 28, 2018
@Nix4Life Would definitely love to see what you have come up with to compare. 1st boot package via HTTP is interesting as well :).
For me the biggest factor was full automation. My goal (mostly completed) is to boot a machine to USB, and in a few minutes have a freshly installed 10.13, and enrolled in MDM, with no user interaction.
  • March 2, 2018
hey @chrisdaggett,
just to circle back. We were able to get apfs restored and working. we are piecing this together. I cant take full credit as its a mashup of Greg N's bootstrappr and Rich T's first boot generator and a bunch of admins around the world figuring this out. we will script it to be 99% automated, minimal input by the techs(mount dmg, enter hostname). So the steps are the same: create autodmg afps with (localadmin,munki,first boot). boot into recovery. do a http restore(4-6 mins),mount volume/containers, reboot, pull down packages. They are still looking at MDM solutions, so once they have it we will bake that in. both restores were tested on 10.12.6 machines. They are not in rush, we just wanted to get something ready if and when they decide. As always until Apple makes changes or breaks things.
  • March 5, 2018
FYI in my testing as of 02/28/2018 I updated to the latest version of Sierra 10.12.6 and the firmware update was pushed from the app store. (This method may still potentially work if you don't have time to update to 10.12.6 or are running El Cap, although I have not tried the standalone firmware update in El Cap. (Now, with the latest firmware, NetResotre of High Sierra 10.13.3 works like a charm.)
  • April 5, 2018
Hi Nation, just a FYI,
the above method is still working for us using 10.13.4 with AutoDmg 559beta
L
  • April 11, 2018
Hi Nation,
Does anybody know, if I wanted to get a non 10.13 computer onto 10.13 with a fresh install, will I still need to use the above methods?
Use case: We are currently upgrading everybody to 10.13, but for those computers sitting in the stock room that are 10.12, I want to deploy it with 10.13 (fresh image like a brand new computer). I'd hate to have to format the drive with a fresh 10.12, and then run the high sierra install from the app store, this would take forever.
Thoughts?
Ryan
  • April 11, 2018
@ryan.er If you have SSD drives, I'd suggest getting to APFS so you can take advantage of future benefits APFS brings (at least startosinstall -erasedisk). Here Apple lays out their supported methods of installation for macOS.
Netinstall works, but you have to support netinstall which Apple is pushing off to open source projects. Apple did publish a migration guide for getting Netinstall to work on macOS, but I'd hate to support that long term. At least with 10.13.4, don't waste your time trying to use automated netinstall as in my testing it left some SSD machines HFS.
We have a few thousand macs we need to get from 10.12 --> 10.13 (APFS) this summer. We want to stick with apple supported methods, so we're using bootable installers on USB drives. macOS install time varies from 25-45 minutes depending on the hardware (for us, 2014/2017 Airs are 25 minutes and 2015/2016 8GB Airs are 35-45 minutes).
What really is frustrating is jamf doesn't support startosinstall so far in any way with their tools. We're paying a lot of money for jamfs tools and open source tool imagr has supported a wipe of the drive, convert to APFS, and loading macOS via supported startosinstall command (which updates firmware) since OCTOBER. Here we are in April and jamf still is shrugging every time I ask them how they're going to support startosinstall.
You can use the above methods that @chrisdaggett and @Nix4Life have put a lot of time into get working. They're not supported by Apple, but probably will work great and are faster. imagr is another (albeit slower option), but it is using apple approved methods to get clients to APFS and 10.13.
I really hope no matter what 3rd party option people are using to get to 10.13, they are asking their jamf reps where they are with startosinstall support.
PS - there's this blog post that could be used once you get machines to 10.13 to "erase all contents and settings." It requires you're APFS, and again, I'd like to see some supported documentation from the jamf side on supporting something like this.
  • April 17, 2018
I can not get autologon with root to work on a build disk. i tried using the commands above with no luck. tried with and without a password, anyone got any good ideas? My disk is 10.13.3 at the moment.
  • May 2, 2018
I was able to extract and build the FirmwareUpdateStandalone.pkg. But upon installation, I get an error, the installation failed. "The installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance." What did I do wrong?
  • May 2, 2018
@CasperSally I have the script from that blog set in a policy with a custom trigger for "reimage"
I packaged an AppleScript application and left it in /Library/CompanyName for support techs to run. The AppleScript simply runs the shell command to run the custom trigger. The Application is set to warn all that the machine will be reimaged.
  • May 3, 2018
@chrisdaggett a useful check to build into your script would be to check if the firmware update is already applied. I found this somewhere else a while back and it seems to work. This will be run from the boot disk and inside the script used to install the firmware, just use the output in an if statement.
testEFIState () { current_efi_version=$(/usr/libexec/efiupdater | grep "Raw" | cut -d ':' -f2 | sed 's/ //') echo "current_efi_version $current_efi_version" latest_efi_version=$(ls -La /usr/libexec/firmwarecheckers/eficheck/EFIAllowListShipping.bundle/allowlists/ | grep "$current_efi_version") echo "latest_efi_version $latest_efi_version" if [ "$latest_efi_version" == "" ]; then echo "EFI not upto date" efiCheck="pass" else echo "EFI upto date" efiCheck "fail" fi }
  • May 16, 2018
Having the same issue as @jjbauer81 . I was able to extract and build the FirmwareUpdateStandalone.pkg. But when I go to install it on a 10.12 machine, I get the same error he/she did.
  • May 22, 2018
i had this working on friday when i left work, i reimaged my computer with it, it works very well! now this morning with 0 changes now it wont lay down my image it's saying there isnt enough space to lay down the image. so frustrated!!!
chrisdaggett
  • June 7, 2018
One update, When capturing the image make sure you do it form a machine using 10.13.3 or lower. Apple has botched something in 10.13.4+ with HDutil/Diskutil and it will fail to scan/restore!
Also realized after some further testing that I had to make some tweaks to the imaging script so that has bee updated in the OP.
  • June 8, 2018
@chrisdaggett I'm having a difficult time wrapping my head around this:
"you will have a freshly imaged machine on 10.13 with the correct Firmware and APFS!"
Do you mean a factory version of the image? Or an image with apps, settings, etc.
What's the purpose of doing this way?
What issues or pain points is this method addressing?
chrisdaggett
  • June 14, 2018
@upworkadmin I mean with apps, settings etc.. You could just as easily use this method for a factory image though (just do a fresh install and take an image before doing anything else)
When you run as many customizations as we do, with 2000+ laptops, it makes things much easier and smoother. It saves enormous amounts of time and alleviates MANY points of failure. Every time you have a seperate package, or script, etc.
I can have a machine fully reimaged exactly the way we need them in under 5 minutes. Simply can not be done with fresh install/packages/etc.. As discussed if this isn't your cup of tea that is perfectly fine, for many of us this is the best way to get what we need done. I am not doing a fresh install on 2k machines at 40m a wack (before customization/packages/etc). Doing it the Apple approved method would take me over an hour per run. Right now I can do ~50-60 machines at a time (by myself) and have an entire round done in about 5 minutes. Not an hour+ to get the same 50-60 done. When you are doing this on 2k machines, by yourself, that matters :-D. Literally have had ZERO issues with imaging across any version of OSX/macOS, regardless of what Apple states. Like the OP says though, this is not approved, and not for everyone. I just share for others that want/need some of this method.
AVmcclint
Forum|alt.badge.img+21
  • June 14, 2018
@chrisdaggett DILLY DILLY! Apple has lost the focus on Enterprise. This is evidenced by the fact that they keep removing all the tools that make Mac admin's lives better. "Having true server grade hardware to run a Server version of OSX makes IT managers happy? too bad we're killing the XServe. Your Server software (10.6.8) does exactly what you need and is stable as hell? Too bad we're going to start the long painful road of crippling it. Having your own DNS, Mail, Netboot, Software Update server with easy to use management is perfect for small IT departments? Too bad we're just going to toss those out the window. 5 minute imaging saves you time and money? You can kiss that goodbye too."
chrisdaggett
  • June 14, 2018
@marklamont In case anyone else goes to use it there is an Equal sign missing in the script :).
Also the up to date, and not up to date, are backwards. (the pass and fail are correct)
Should be:
efiCheck="fail"
chrisdaggett
  • June 15, 2018
I uploaded my new imager for those that want to mess with it or take a peak. Also updated OP with script updates and updated instructions. https://tinyurl.com/yacat44e
