Automate User and location Details
  • November 9, 2023
  • 17 replies
  • 166 views
_aDiedericks
Hi there,
We currently have Google Workspace configured in Jamf Pro. This allows us to manually search for users in "Users and Location" to assign them to a device.
We also have Jamf Connect in our environment that associates the local account with an Okta account which is linked to the user's Google Workspace email.
Is there some way to automate assigning user details into User and location based on the username of a logged in user?
Best answer by Deku91
this is what I use in my enviroment and is working good.
# Get current signed-in user
currentUser=$(ls -l /dev/console | awk '/ / { print $3 }')
# com.jamf.connect.state.plist location
jamfConnectStateLocation="/Users/$currentUser/Library/Preferences/com.jamf.connect.state.plist"
# Check if the plist file exists
if [ -f "$jamfConnectStateLocation" ]; then
# Read DisplayName from the plist file
DisplayName=$(/usr/libexec/PlistBuddy -c "Print :DisplayName" "$jamfConnectStateLocation" 2>/dev/null)
if [ -n "$DisplayName" ]; then
# Upload DisplayName to Jamf Pro if it's not empty
if [ "$currentUser" != "root" ]; then
/usr/local/bin/jamf recon -endUsername "$DisplayName"
echo "DisplayName not found in $jamfConnectStateLocation"
echo "Plist file not found: $jamfConnectStateLocation"
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • November 9, 2023
You might find my JNUC video from a couple of years ago useful:
How to collect user information and apply it throughout Jamf Pro | JNUC 2021
A_Collins
  • November 10, 2023
you can run recon with the logged in user, jamf would populate the mapped fields.
#!/bin/sh # logged in user loggedInUser=`/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }'` # Run recon /usr/local/jamf/bin/jamf recon -endUsername $loggedInUser
_aDiedericks
  • November 10, 2023
'com.jamf.connect.state.plist' reports more accurate data. Would it be possible to read 'email' and use it as Username within User and Location and the 'name' value as Full Name in User and Location? I tried to find some examples of people pulling data from sub-categories within a key in a .plist. It's mostly just people pulling the key value itself however these are categories within a single key so I'm not sure how to pull the values after 'name = ' and 'email = '
_aDiedericks
  • November 10, 2023
Alright, so here's what I have so far to do what I need in case anyone else finds this useful
#!/bin/sh fullName=`defaults read com.jamf.connect.state |grep -E 'name ='|grep -o '"[^"]\\+"'` emailAddress=`defaults read com.jamf.connect.state |grep -E 'email ='|grep -o '"[^"]\\+"'` /usr/local/jamf/bin/jamf recon -endUsername $emailAddress -realname $fullName -email $emailAddress
  • November 11, 2023
_aDiedericks
  • November 11, 2023
I made some adjusts to the above script. This is the current working solution for my above issue.
#!/bin/bash cat <<'EOF'> "/private/var/tmp/PopulateUserData.sh" fullName=`defaults read com.jamf.connect.state |grep -E 'name ='|grep -o '"[^"]\\+"'|cut -d\\" -f2` emailAddress=`defaults read com.jamf.connect.state |grep -E 'email ='|grep -o '"[^"]\\+"'|cut -d\\" -f2` sudo /usr/local/jamf/bin/jamf recon -endUsername "$emailAddress" -realname "$fullName" -email "$emailAddress" EOF chmod a+x /private/var/tmp/PopulateUserData.sh currentuser=`stat -f "%Su" /dev/console` su "$currentuser" -c "/private/var/tmp/PopulateUserData.sh" sleep 10 rm -rf /private/var/tmp/PopulateUserData.sh
_aDiedericks
  • November 13, 2023
Just said some failures in our test environment with this script. Seems when I was testing since I was forcing policy update from Jamf using the 'sudo jamf policy' command it elevates permissions for the script as well but if you let the policy execute on its own it requires admin permissions.
_aDiedericks
  • November 13, 2023
I can confirm your script works perfectly. Is there any way to pull the 'name' attribute using this method with PlistBuddy?
I've tried by just replacing the 'DisplayName' key with 'name' and it doesn't seem to work. I think it's due to the 'name' key being a sub-category (key) to the 'IdToken' key.
  • November 13, 2023
Try this and see if it works for you
# Read name from the plist file
Name=$(/usr/libexec/PlistBuddy -c "Print :name" "$jamfConnectStateLocation" 2>/dev/null)
if [ -n "$Name" ]; then
# Upload Name to Jamf Pro if it's not empty
/usr/local/bin/jamf recon -endUsername "$Name"
echo "Name is empty or not found in $jamfConnectStateLocation"
_aDiedericks
  • November 13, 2023
I get the error
"Name is empty or not found in /Users/'x'/Library/Preferences/com.jamf.connect.state.plist"
This looks like the exact way I adjusted your original script to account for the name key that didn't work.
  • November 13, 2023
I get the error
I don't know how to make that work then, sorry. With the above script I get what I need for Jamf Pro.
_aDiedericks
  • November 13, 2023
When you update the username to email does it automatically populate all the other data? Or are you clicking search and manually assigning the credentials?
  • November 13, 2023
It does it automatically, if you have more questions you can search for me in Slack as Arturo Yumpo.
_aDiedericks
  • November 13, 2023
Managed to get it right here. For me it doesn't auto populated once the username is present but found a way to specify a sub-key
#!/bin/sh # Get current signed-in user currentUser=$(ls -l /dev/console | awk '/ / { print $3 }') # com.jamf.connect.state.plist location jamfConnectStateLocation="/Users/$currentUser/Library/Preferences/com.jamf.connect.state.plist" # Check if the plist file exists if [ -f "$jamfConnectStateLocation" ]; then # Read DisplayName from the plist file preferredUsername=$(/usr/libexec/PlistBuddy -c "Print :IdToken:preferred_username" "$jamfConnectStateLocation") fullName=$(/usr/libexec/PlistBuddy -c "Print :IdToken:name" "$jamfConnectStateLocation") if [ -n "$preferredUsername" ]; then # Upload DisplayName to Jamf Pro if it's not empty if [ "$currentUser" != "root" ]; then /usr/local/bin/jamf recon -endUsername "$preferredUsername" /usr/local/bin/jamf recon -realname "$fullName" fi else echo "DisplayName not found in $jamfConnectStateLocation" fi else echo "Plist file not found: $jamfConnectStateLocation" fi exit 0
  • November 13, 2023
if it doesn't auto-populate make sure your Mapping is correct and that you also have Buldings and Departments created in Jamf Pro
  • August 29, 2024
Where can I find the 'com.jamf.connect.state.plist'? We use Jamf Connect as well but can't find that plist anywhere on the device. I even browsed the file path.
  • August 29, 2024
Disregard. I was testing with a recently wiped test machine and it didn't have JC configured yet. 😅
Script @Deku91 provided worked great!
