Never mind, went with the authchanger -reset -okta and that solved the issue.
hi
I also have the same issue. When i login to the mac after enrolling the user in jamf connect via okta, I am not asked to migrate the existing local account and a new profile is created instead.
My login plist is like this:
{UIDTool=, OIDCClientSecret=, OIDCROPGID=, DenyLocalExcluded=[], LocalFallback=true, MigrateUsersHide=[], HelpURL=, EnableFDE=true, LicenseFile=, OIDCIgnoreCookies=false, ScriptPath=, ROPGDiscoveryURL=, ROPGRedirectURI=, OIDCProvider=Azure, LocalHelpFile=, AllowNetworkSelection=true, AuthUIOIDCProvider=, OIDCAdminAttribute=, CreateSyncPasswords=true, AuthUIOIDCRedirectURI=, OIDCAccessClientID=, AuthUIOIDCClientID=, AuthUIOIDCTenant=, BackgroundImage=, OIDCIgnoreAdmin=false, OIDCTenant=, DemobilizeUsers=false, EnableFDERecoveryKeyPath=, Migrate=true, AuthServer=topia.okta.com, ROPGTenant=, LoginScreen=true, OIDCRedirectURI=, OIDCDiscoveryURL=, ROPGClientSecret=, DenyLocal=false, RightsTmpCache=false, OIDCAdminClientID=, OIDCNewPassword=false, LoginLogo=, OIDCSecondaryLoginClientID=, ROPGProvider=Custom, OIDCAdmin=, MessageOTPEntry=, EULAPath=, OIDCClientID=, CreateAdminUser=false, ScriptArgs=, OIDCAuthServer=, EULATitle=, EULASubTitle=, HelpURLLogo=, EnableFDERecoveryKey=false, CreateVerifyPasswords=false, EULAText=}
What was the solution for you exactly?
thanks
