Jamf Connect
  • March 12, 2024
  • 35 views
JamfAdmin2
I need help.
Hello I am looking to deploy Jamf Connect to existing users computers.
We have Config profiles and policies setup and scoped to our test machine.
But when we scope our test device nothing happens no matter how many sudo jamf policy I run jamf connect does not appear on our device.
There is also the option with Mac Apps which seemed to work just took a while for it to reach our test machine. The only thing with the Mac Apps the menu bar appears which is good but it does not have our company logo when we sign in through the menu bar it has the jamf connect generic logo.
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • March 12, 2024
Be sure you're installing the configuration profiles before you install the Jamf Connect software. It's the profiles that tell the installer how to set the correct login window.
If you did install the software first, you can either re-install it or use the authchanger command to set the login window to appear.
JamfAdmin2
  • March 12, 2024
Is this in regards to MAC Apps?
