Jamf Connect Wi-Fi networks are currently unavailable
  • December 12, 2024
  • 19 replies
  • 868 views
We have gotten some feedback from users that are working remotely about our Macs imaged through Jamf Connect. Users are seeing the message on their wifi, "Wi-Fi networks are currently unavailable." Users without hardline options are unable to login to the machines.
We are currently using Jamf Connect v. 2.37.0
Has anyone seen this issue before and if so, how did you resolve it?
Note: Potentially 16 machines affected as we halted production until we resolve this.
Best answer by patrickj
You could be hitting the following product issue.
  • [PI119511] The Jamf Connect login window currently displays the following message, even while computers have an active network connection: "Wi-F networks are currently unavailable".
This product issue is resolved in Jamf Connect 2.41.0 according to the release notes.
AJPinto
  • December 13, 2024
Are the users at the same location or different locations? Have the users tried known working networks like a cellphone hotspot just to see if the Mac can see the network?
I have to poke fun on this: "Macs imaged through Jamf Connect" is wrong on so many levels :). You can't "image" Macs, and "Jamf Connect" is not a management tool. Macs would be configured by Jamf Pro and have Jamf Connect installed as a part of the configuration.
patrickj
  • December 13, 2024
  • December 13, 2024
Ended up being the issue. We are upgrading our Jamf Connect version now so we won't run into it again.
Thank you!
  • December 16, 2024
Well, as TWF informed here, we able to upgrade to 2.42.0 the latest Jamf Connect and the Problem still persist.
"Allow network selection" is activated on the configuration Profile. it work as normal if we login one second time with the local Account.
Anyone an idea what can cause this?
  • January 21, 2025
This issue still persist even with version 2.43.0. We researched on web and looks it's not fully solved until July 24. Yes, we have workaround but it's impacting onboarding and someone should be giving us ETA...
davehansbury
  • January 22, 2025
Yes, seeing with with an M4 Mac mini and M4 MacBook Pro running Sonoma 15.2 and and JC 2.43.  Could I ask what you're doing as a workaround?
jimi00
  • January 22, 2025
Running into this issue as well with JC 2.43. ADE process starts on M3 MBAs running Sequoia. Wifi selection then remote management appears as expected. No user creation in setup assistant. JC is installed during prestage, and as soon as JC's first login window appears, wifi is disconnected and network selection is unavailable.
Having the same issue, going back and for with support right now.
  • January 29, 2025
I'm still having this issue and would love to know what you are using as a work around for now.
vickih
  • February 25, 2025
Taylor,
Let us know please what Jamf's workaround/solution is.  My only way around this was to use an ethernet adapter.  Then I was able to uninstall it.  IMO Connect here recently seems to be more problematic.  I have our users on patch management roll out so they will receive the latest version as Connect is constantly updating.
In previous versions I use to be able to uninstall Connect using Terminal in Recovery deleting the different databases now I can't even do that...
cd /Volumes/Macintosh\\ HD/var/db
I am curious if I exclude the 1 machine / computer (in my case)  out of all of the configuration profiles regarding Jamf Connect (I have 3) if I can login locally.
  • February 27, 2025
Taylor,
This week we ended up upgrading our dev instance to 11.14 and our JC package to 2.44. This resolved the wifi missing issue. We are going to test in our prod environment to see if everything continues working.
vickih
  • February 27, 2025
Thank you for getting back to me. I am on v11.13 but I'm cloud-based so
that will be updated Feb 28 or March 1 according to the schedule. And I am
already using 2.44 of Jamf Connect.
Good luck!
VickiH
[image: Photo of Vicki Holzknecht]
Vicki Holzknecht
Cyber Security Analyst
_E-mail correspondence to and from this address may be subject to the North
Carolina Public Records Act and shall be disclosed to third parties when
required by Chapter 132 of the North Carolina General Statutes._
patrickj
  • March 6, 2025
Jamf Connect 2.45.0 released 3/6/2025 now includes the following fix:
  • [PI121901, PI123774] The Jamf Connect login window no longer incorrectly displays "Wi-Fi networks are currently unavailable" during login, and now correctly indicates which network is currently selected on computers running macOS 15 Sequoia.
  • March 6, 2025
Just saw this email about the release come through. Sounds promising and we'll definitely be testing it this week!
vickih
  • March 6, 2025
Thank You, I will wait for Jamf to update it in the Jamf App Catalog.
VickiH
I am currently experiencing an issue where my Wi-Fi networks are unavailable, making it difficult to proceed with tasks. I need assistance in resolving this connectivity issue. Additionally, I would like to Book Appointment for further assistance with any services related to the matter.
vickih
  • April 4, 2025
Do you know what version of Jamf Connect you are using?
VickiH
  • April 4, 2025
VickiH
2.45 is our current version. We are no longer having issues with it. Jamf Pro version 11.14 as well. We have had multiple successful rollouts of JC with this version.
MateuszGrochulskiDSS
I had this problem on 2.45.1 versionjamf connect and macos 26.2. any one has still the same problem?
