Invalid Response Code: 401
  • January 8, 2025
  • 10 replies
  • 141 views
We were using Jamf Connect with Azure/Entra for about a year without issue, it's only used on a small number of clients and I'm unsure how often the computers are actually used, but at the moment none permit authentication.
I've trimmed down the config to the barebones, and even recreated the app registration in Entra without any change.
Any user attempting to sign in sees Invalid Response Code 401 from https://login.microsoftonline.com and it gets no further.
The original working plist for jamf.connect.login included, the following, but has been well trimmed down to just app registration IDs and secrets without any change.
<plist version="1.0">
<dict>
<key>AllowNetworkSelection</key>
<true/>
<key>BackgroundImage</key>
<string>/usr/local/share/jc.jpg</string>
<key>CreateAdminUser</key>
<false/>
<key>CreateJamfConnectPassword</key>
<true/>
<key>DemobilizeUsers</key>
<true/>
<key>LoginWindowMessage</key>
<string>DU Welcome</string>
<key>Migrate</key>
<false/>
<key>OIDCAdminAttribute</key>
<string>roles</string>
<key>OIDCClientID</key>
<string>ABC</string>
<key>OIDCClientSecret</key>
<key>OIDCIgnoreCookies</key>
<true/>
<key>OIDCLocalAuthButton</key>
<string>CIS Login</string>
<key>OIDCNewPassword</key>
<false/>
<key>OIDCProvider</key>
<string>Azure</string>
<key>OIDCROPGID</key>
<key>OIDCRedirectURI</key>
<string>https://127.0.0.1/jamfconnect</string>
<key>OIDCTenant</key>
<string>XYZ</string>
<key>OIDCUsePassthroughAuth</key>
<true/>
<key>OIDCAdmin</key>
<array>
<string>Administrator</string>
</array>
</dict>
</plist>
RaxiaDK
  • January 8, 2025
Hello
Have you try run it in the config app, that come with Jamf connect pkg?
  • January 9, 2025
Using the app, the test fails saying provider unable to be contacted
  • January 9, 2025
Unable to load your identity provider
The identity provider for your system is unable to be contacted. Check network settings or contact technical support.
RaxiaDK
  • January 9, 2025
Here is mine, that working in hybrid mode
com.jamf.connect: https://pastebin.com/epwhT4at
com.jamf.connect.login: https://pastebin.com/63xw0iEn
RaxiaDK
  • January 9, 2025
  • January 9, 2025
Thanks for that, do you know where you get this from entra?
  1. <key>ROPGDiscoveryURL</key>
RaxiaDK
  • January 9, 2025
no, I use ADFS infront of mine Azure
RaxiaDK
  • January 9, 2025
try this guide
https://hcsonline.com/support/white-papers/how-to-configure-jamf-connect-with-microsoft-azure
edit
its a old guide
  • January 9, 2025
according to entra, authentication is fine - showing success against the app
jamiesmithJAX
  • February 28, 2025
@pchrichard were you ever able to resolve this?  I am just starting to implement Jamf Connect now and I am encountering this exact thing.
