We have a Mac that was re-enrolled by a tech. trying to log in to our admin account on the machine failed after that. The tech changed the password locally to the correct password and could logon but policies like reissueing the FileVault key were failing to authentication errors. To fix it we decided to: remove the Mac from Casper, remove the Casper profile from the machine, remove the framework, delete the admin account, reboot, re-enroll in Casper. In theory that should have fixed everything.
The problem is the admin account is reporting as admin in Casper but showing as a standard user on the Mac. Also, pushing packages to the Mac are coming up with Could not mount distribution point "CasperShare". Also, when I try to remote in I get: "An incorrect username/password is entered for this computer."
Any ideas on how to fix this?
