Hello,
We have a problem with Jamf Connect Verify , when we change the local password manually ( lost password ) , a window appears at the start of the session asking us to update the Jamf Connect Verify password in the keychain.
Is there a way to automatically push the password change in the keychain? I saw that there was an attribute for PLIST in the Jamf Connect Verify doc: "KeychainItems" => it didn't change anything but I probably use it wrong.
Thanks for your help.
Here is the message we get after changing the local password, it persists after reboot :
optional image ALT text
And no password works...
This is happening in my testing with conversion of existing domain joined laptops. I was able to leave it blank and it worked. However, it still comes up after reboot and my keychain is screwed up. No passwords are saved and I have to keep logging into stuff. If this happens for a regular user this is going to be a massive issue with a lot of tickets.
