Jamf Connect 1.19.2 Release
  • June 4, 2020
  • 0 replies
  • 16 views
Jamf Connect Configuration 1.9.0: N/A
Jamf Connect Login 1.11.4 Bug Fix: [PI-008291] Replaced a missing file from the Jamf Connect installer which caused the Pluggable Authentication Module to fail.
Jamf Connect Sync 1.4.3: N/A
Jamf Connect Verify 1.5.3 Bug Fix: [PI-008003] Fixed an issue that caused Jamf Connect Verify to sometimes launch as two separate instances, creating a duplicate menu bar icon.
Product Documentation
For more information, including Release Notes, please see the Jamf Connect Administrator Guide.
