JAMF Connect login sso screen no network message
  • September 3, 2020
  • 0 replies
  • 16 views
perryd84
Wondered if anyone knew a way to customise the SSO screen when there is no network connection?
At the moment all you get is a naff generic, "Unable to load identity provider" message. It would be great if you could edit this with a logo and some text explaining that the user needs to connect it to wifi or network?
