If I want to upgrade Office with a new package (complete new install) is it possible to use depnotify ? - or can this only be used when a mac is starting up the first time and part of dep ?
Do any has some good tutorial on using Depnotify. I have seen the official githib, but I need some examples code, to be able to understand what is needed. Don´t know if any has some links ?
Also, if other tools can be used when installing larger packages so there is a visable box with information for the user, and not only the "slide in and slide out" notification
