Users are able to use their authentication on the Jamf Connect login screen through Azure AD SSO. Then, Jamf Connect login screen prompts to users to put their password for their computers.
However, as shown in the picture above, the message makes them confuse to put their home network password. So, I am requesting a feature for adjusting the custom message on the Jamf Connect login.
