How to Force Apps to update on iPad Jamf Now
  • December 17, 2023
  • 0 replies
  • 41 views
I work for an MSP and we use Jamf Now to manage a clients iPad devices. With Jamf Now we have it setup to auto update applications but we have noticed this feature will not work when the app is open. They use these iPads to access there EHR and they always have the app open. Most of them lock the ipad with it still open. This prevents the app from updating even if we manually push the update to the device, it won't install until they close the app.
I have looked at Jamf's documentation on auto updates and all I see is you can turn it on. No option to set a time to update.
Is there anyway we can force apps to update at 3am while they are not using it?
