Automate Icloud account and Prepopulate for Vantagepoint?
  • March 5, 2024
  • 18 views
Hello,  we currently distribute ipads to users and then walk them through entering Vantagepoint server info and registration. We also do the same for apple id registration. I was wondering if it is possible to automate this info using Jamf? Like for example, once a user is assigned to an ipad in Jamf, is there a way for Jamf auto sign into their icloud account?
For Vantagepoint, would their be a way to prepopulate server info?
Thank you!
Best answer by Tribruin
There is no way to automate signing in to iCloud. That is a user function.
Check with Vantagepoint and see if their app supports a Managed Configuration that you can supply the server information as part of the install.
1 reply
Forum|alt.badge.img+20
  • March 5, 2024
