Could not update placeholder 'iPad xxxx' for serial 'XXXXXXXXXX', the DEP placeholder doesn't exist
  • January 25, 2023
  • 84 views
When I trie to import placeholders I get an error.
CSV file for testing is
SerialNumber,Identification,AssetTag,AssignToUser,MemberOfGroups,AutomatedDeviceEnrollmentProfile,DeviceName,Location
XXXXXXXXX,iPad xxxx,PADSX02,,BBBBBB - CCCCCC D,BBBBBB – DEP-profile,%AssetTag% - %SerialNumber%,Location X
I have 'BBBBBB – DEP-profile' in Automated Device Enrollment Profiles and this works If I manually assign it to the devices. Profile name is double checked.
AutomatedDeviceEnrollmentProfile is descibed in the documents https://docs.jamf.com/jamf-school/documentation/Placeholder_Devices.html
There's a CSV template in xxxx.jamfcloud.com/impex/devices.html but there's no AutomatedDeviceEnrollmentProfile and there are 7 labels but 8 colums???
SerialNumber;Identification;AssetTag;AssignToUser;MemberOfGroups;DeviceName;Location
2019XXXZDSK;Device001;Optional;Optional;Optional,Optional2;Optional;Optional
2019XXXZDSK;Device002;Optional;Optional;Optional,Optional3;Optional;Optional
2019XXXZDSK;Device003;Optional;Optional;Optional,Optional4;Optional;Optional
2019XXXZDSK;Device004;Optional;Optional;Optional,Optional5;Optional;Optional
2019XXXZDSK;Device005;Optional;Optional;Optional,Optional6;Optional;Optional
2019XXXZDSK;Device006;Optional;Optional;Optional,Optional7;Optional;Optional
2019XXXZDSK;Device007;Optional;Optional;Optional,Optional8;Optional;Optional
2019XXXZDSK;Device008;Optional;Optional;Optional,Optional9;Optional;Optional
2019XXXZDSK;Device009;Optional;Optional;Optional,Optional10;Optional;Optional
2019XXXZDSK;Device010;Optional;Optional;Optional,Optional11;Optional;Optional
2019XXXZDSK;Device011;Optional;Optional;Optional,Optional12;Optional;Optional
Best answer by Hpal
I'd pair down that file some unless you absolutely need all of those fields. I only use SerialNumber,Identification,AutomatedDeviceEnrollmentProfile, and AssetTag. Your example shows IPAD XXXX in the ID column maybe tweak that so it's IPADXXXX i.e. remove the space.
The problem was that some how in copy paster the HYPHEN-MINUS character was converted to EN DASH character.
Character - Character name HYPHEN-MINUS Hex code point 002D Decimal code point 45 Hex UTF-8 bytes 2D Octal UTF-8 bytes 55 UTF-8 bytes as Latin-1 characters bytes -
Character – Character name EN DASH Hex code point 2013 Decimal code point 8211 Hex UTF-8 bytes E2 80 93 Octal UTF-8 bytes 342 200 223 UTF-8 bytes as Latin-1 characters bytes â <80> <93>
So triple check was requried.
  • January 25, 2023
  • January 26, 2023
