Morning!
I'm currently trialing Jamf School. Want to test how to use Google authentication during enrollment. I believe I have everything set up: Built Google API Console Project, created credentials, added redirect URIs, copy and saved client ID/secret, then added all that into Jamf School under Authentication method.
On iPads I'm using for trial, I wiped and reset. iPad went through enrollment easily enough.
But I expected to come up on a Google sign in page which needed authentication. But nothing shows up. Just normal enrollment steps.
My questions - What should I be expecting?
How can I use Jamf School and Google in a 1-1 iPad setting?
- Kevin
