Script to connect smb share at login and place in favorites location in Finder or Desktop
  • March 23, 2023
  • 0 replies
  • 26 views
Hello all,
    I've tried difference scripts (bash and AppleScript) but none seem to work for me.  Basically, (and I see this has been asked a lot but varies), I would like for any user that logs into the Macbook, connect to their smb share AND place that drive as a shortcut in either the Locations (in Finder) OR Desktop.  Users should not be prompted for their username and password.  Here's what the smb path looks like:
smb://servername/Userdata/UserName/My%20Documents
Where UserName can be any user that logs in to that Mac device.  But do not prompt for username and password if possible.  If password is a must, then I'll take whatever I can work with.
