MS App Install with Jamf School
  • August 16, 2023
  • 12 views
Trying to install Microsoft Apps with jamf school and receiving an error " License not found". Has anybody experienced this and knows how to resolve it?
1 reply
AJPinto
  • August 16, 2023
If you are using the AppStore, make sure you have VPP licenses and they are assigned correctly. However I very strongly recommend not using the AppStore version of MS Office. Instead get the installers from macadmins.software, and setup Microsoft Auto Updater to handle updates.
