Lost Mode via API for Jamf School (formerly ZuluDesk)
  • October 7, 2020
  • 40 views
Hi all, I'm wondering if there is an undocumented API call for Lost Mode in Jamf School, since it's not in the docs. I used this extensively with Jamf Pro back in the day and am going to be in rough shape if there's not a similar API call for the School product...
Ryan
  • September 1, 2022
I was just looking for the same thing. Sounds like the answer is no?
  • November 18, 2022
hopefully there will be some movement in the api development. The lost mode endpoint would be a great feature.
