Export with the SerialNumber
  • December 21, 2023
  • 4 replies
  • 202 views
JamFm
Hi
we need the most important Infos from the User but we miss at the export the SerialNumber. This means that I have to combine the data from the categorie „Devices“ and the „user", which is very cumbersome.
Export from categories "Users" Columns
UserFirstName
UserLastName
Username
Email
Managed Apple ID
Groups
Devices
It will be very well, if we could export with the SerialNumber and not if the user have a Device 1 or not 0.
UserFirstName
UserLastName
Username
Email
Managed Apple ID
Groups
SerialNumber
Or have anyone an idea, where I can extract/export the Infos (see the upper chart)
Thanks for help!
Peter
mfletch
  • December 21, 2023
If I'm understanding what you're asking, all you need to do is add serial number to the Inventory display.
Go to Settings>Computer Management>Inventory Display and click on the Hardware tab and look for serial number and select it. Back out to the Jamf home page and click Computers and Search Inventory>Search and when it shows all computers you will have a serial number column. Now when you export from there, serial number will be included.
JamFm
  • December 21, 2023
Hi
I could't find Settings>Computer Management>Inventory
We work with Jamf School
Why can I select under DEvices which information I want to export but not under "Users" e.g. ??Why do you do that?
And the interface does nothing for me, as it only has an effect on the "Devices" category and not on the "Users" category
Peter
JamFm
  • December 21, 2023
Why can't I select under.....
mfletch
  • December 21, 2023
My bad, I'm working with Jamf Pro and based on your reply, apparently, they are different in how you configure this information.
