Remove Individual OS X Configuration Profile via Command Line
  • January 21, 2014
  • 39 replies
  • 430 views
Hoping to get some assistance from the knowledge of the JAMF Nation. I am struggling to remove an individual configuration profile, that was installed manually, via the command line. Testing on Mavericks 10.9.1 currently. Used the profiles man page and this: https://developer.apple.com/library/mac/documentation/darwin/Reference/ManPages/man1/profiles.1.html
Commands I've tried:
sudo profiles -R -F /tmp/profilename.mobileconfig
sudo profiles -R -p profileidentifier
sudo profiles -R -p profileidentifier -U username
No dice so far. Use case is that a profile is installed manually and it needs to be removed without removing all profiles. Any thoughts out there?
Ben
  • January 21, 2014
i use the profiles -R -p profileidentifier all the time
use profiles -P to get the identifier before hand, maybe you are using the wrong identifier.
  • January 23, 2014
We've had to do the same thing in our environment, and I found the uninstall has to be formatted like:
profiles -R -p com.apple.mdm.server.corp.company.com.123af456-78e9-112-123a-123a456789.alacarte
...and like @nessts said, you'll need to get that whole identifier string from the
profiles -P
``` command. If you have a password required to uninstall the profile, that'll still be necessary from the command line, like it would through the gui. Hope that helps!
  • September 3, 2014
Is there a way to remove user level MDMs from multiple users (Like SCEP or AD Certs)?
  • September 8, 2014
From what I have found out, apparently not. I am looking for the same thing myself. An woeful omittance on behalf of Apple i think.
scottb
  • September 8, 2014
Has anyone read about changes in 10.10 that might make this more versatile? Just curious. No NDA breakage, just wondering if anyone has read anything about it?
  • September 8, 2014
This is what I wrote to remove a MDM based on the name. Profile name being the fourth variable passed.
## Get UUID of requested MDM Profile
MDMUUID=`profiles -Lv | grep "name: $4" -4 | awk -F": " '/attribute: profileIdentifier/{print $NF}'`
## Remove said profile, identified by UUID
if [[ $MDMUUID ]]; then
    profiles -R -p $MDMUUID
    echo "No Profile Found"
sleep 5
  • March 30, 2015
Just because I needed it today...
I have created a script to look for a profile name starting with MDM (which seems to be what our evnironment has), it then removes it and runs jamf manage to get it back again.
I have set this in Self Service as a way for people who for whatever reason weren't getting updated policies.
It's not particularly elegant and would probably remove the first profile starting with MDM, so if you have other policies so named it's probably not for you...
echo
MDM_UUID=$(profiles -Lv | awk '/attribute: name: MDM/,/attribute: profileUUID:/' | awk '/attribute: profileUUID:/ {print $NF}')
echo $MDM_UUID
if [ -z "$MDM_UUID" ]
then
echo "-MDM profile NOT found. Attempting to manage-"
jamf manage
echo "-MDM profile found. Removing MDM before attempting to manage-"
profiles -R -p "$MDM_UUID"
sleep 5
jamf manage
echo
  • February 6, 2016
Even as a root/admin user the profiles cannot be removed. Any suggestions?
_computerlevel[1] attribute: profileIdentifier: 00000000-0000-0000-A000-3A414D460003
>>profiles -v -R -p 00000000-0000-0000-A000-3A414D460004
profiles: verbose mode ON
profiles uninstall for identifier:'00000000-0000-0000-A000-3A414D460004' and user:'root' returned -205 (Unable to locate configuration profile.)
profiles: returned error: -205
rqomsiya
  • February 27, 2016
@Jand99 I'm having the same issue. Running into error -205. Did you find a solution??
Thanks,
R
  • February 29, 2016
Solution is simple if you have admin rights.
Assuming that "sudo jamf removeFramework" did not work you can try this:
Start terminal and type:
sudo -i
cd /var/db/
mv ConfigurationProfiles ConfigurationProfilesOLD
then reboot. A new empty ConfigurationProfiles folder will be created automatically.
NOTE: If you need to keep some special configuration profiles in that folder it may be better to only delete the file in /var/db/ConfigurationProfiles/MDM_ComputerPrefs.plist file.
rqomsiya
  • February 29, 2016
Well i actually have a config profile that is for wi-fi access. We manually packaged it and installed via script. However, i can't remove it. I keep getting the -205 error. I'm running the simple command
profiles -R -p UUID (of the file in question)
  • April 7, 2016
passcode protected?
dstranathan
Forum|alt.badge.img+19
  • August 25, 2016
Related question: When a configuration profile has been removed from a JAMF Managed Mac manaully (command or script), will the profile get reinstalled automatically via MDM at some point (assuming the target Mac is still scoped for that particular profile etc)?
donmontalvo
Forum|alt.badge.img+36
  • August 25, 2016
@dstranathan will until out of scope
  • December 6, 2016
@Jand99 You're a genius, that was the answer I was looking for. I ran your commands after doing -removeFramework and then re-enrolled with a QuickAdd and WIN!
Thanks a bunch.
  • December 22, 2016
+1 for @Bauer from way-back-when, had a manually- (not JAMF-) distributed config profile which just wouldn't go away. Syntax is everything!
Chris_Hafner
Forum|alt.badge.img+27
  • January 3, 2017
Just to clear up a question I had when reading this post all this time later. For those using secured, manually installed profiles. Removal of such a profile using a command:
requires the profilename.mobileconfig to be loaded into /tmp/ again. For most of you, this is totally obvious as the command calls for it. This means if your original install policy copied the "profilename.mobileconfig" to the /tmp/ directory to install it, you will need to again copy the "profilename.mobileconfig" to the /tmp/ directory before you can uninstall it.
Just to help future newbies!
  • April 22, 2017
Hey everyone,
I need to remove a specific Configuration Profile that was installed via the server on my 10.11.6 machines. I need to remove it via command line in a script for a very particular purpose. Since the Config Profile was installed via the JSS, the simple [ /usr/bin/profiles -R -F] will not work. Does anyone know how to remove a server installed Config Profile via terminal?
  • April 23, 2017
@cdenoia Have you tried using sudo profiles -R -p UUID as shown in some of the posts above? The UUID is the identifier string that you can get by running sudo profiles -P in Terminal.
  • April 24, 2017
Hey @mm2270 ,
Yes, I attempted to issue command: /usr/bin/profiles -R -p <UUID>
Error = "return 101 (profile is not removable)"
Any other ideas??
Try adding -U "creatorofprofile" at the end of the command
sudo profiles -R -p UUID -U magicname
That worked for me.
rqomsiya
  • May 28, 2017
What do you mean by creator of profile?
Sorry for delay, If a profile was installed under a particular username when you run profile -P you should see the username at the start of the string, if you take that username and add it to the end of your command it should remove the profile so if the username was ted your command would look like this
sudo profiles -R -p UUID -U ted
  • June 14, 2017
Just to confirm, @alexmcclements command works.
To put it in a script, you just need to grab the logged in user's username from /dev/console for ex.
user=stat -f "%Su" /dev/console
profiles -R -p "UUID HERE" -U $user
  • May 15, 2019
Remove All Profiles
sudo /usr/bin/profiles -D
Remove a Single Profile
sudo /usr/bin/profiles -R -p com.eugene.
