Hi
We are new to Casper. We tried deployed Adobe CS4 Suite on our machine
through Adobe Install. We deployed it as per the JAM Article:- *Adobe
CS3/CS4 Remote Deployment* - http://jamfsoftware.com/kb/article.php?id=218
For the User logged in Machines, it installed properly without any issues
and working fine. Only issue was mounted Adobe Disk Image on the Finder
Slidebar did not eject evn after it completed the instalation.
For the users who restarted the machine or logged out, it automatically
logged in to user name Temporary Adobe Install user and did not install
properly. It failed to install.
Is this normal because in Adobe CS3/CS4 Remote Deployment Article, first
line says "Adobe Installers require a user to be logged in if you would
like to deploy them remotely."?
If this is normal then suggest me to avoid these issues? Also while
installing any packages(not only adobe) it mounts, will it happen normally?
Regards,
Manoj
