Clear shared ipads users
  • December 13, 2024
  • 7 replies
  • 139 views
I remember before the renovation of jamf dashboard there was an option to clear all users on shared ipad.
Now with the new dashboard I didn't find it, can someone tell me where was that option?
Thank you,
Best answer by dletkeman
On Devices > Inventory select the iPads you want to clear users from and then click the More button in the top right.  From the drop down list select "Clear Cache".  This should have the desired effect.
dletkeman
  • December 13, 2024
GregBobbett
  • December 13, 2024
Is this what you're looking for? I found this in Devices > Inventory > click device > sidebar buttons near bottom > Clear Log History.
dletkeman
  • December 13, 2024
This won't have the desired effect of clearing Shared Users from iPads.
dletkeman
  • December 13, 2024
As a follow up this is documented here:
https://learn.jamf.com/en-US/bundle/jamf-school-documentation/page/Quick_Action_Commands_for_Device_Management.html
  • December 13, 2024
It will be nice that the message about clear cache will be more specific with the result:
  • December 13, 2024
Yes, that only clean the login history 😥
  • October 2, 2025
Is this an only Jafm School thing?  I can’t find an equivalent in Jamf Pro.
