Hello!
We use Jamf School in our school to manage 150+ iPads.
It is necessary to wipe the iPads every 4 weeks.
We notice the following problem:
Some devices “suddenly” lose the WiFi connection. For example: the devices still have a connection on Friday after school ends. But on Saturday they lose connection without anyone touching the devices or WiFi-Settings. Sometimes it seems that the devices are rebooting, but there is actually no reason for a reboot.
Because the students assign codes, as an administrator I have to individually handle all devices that have lost the WiFi connection.
Maybe someone has an idea :/
Dominik
Hi Dominik,
It sounds frustrating dealing with iPads losing WiFi connections. Ensure WiFi profiles are correctly configured, check for Jamf School updates, and use the "Return to Service" option with a Network Configuration Profile when wiping the iPads.
Hope this helps!
Try using the JAMF Reset, Which will preserve the Wi-Fi connection reset the device to the factory settings, and re-configure the device.
https://learn.jamf.com/en-US/bundle/jamf-setup-reset-configuration-guide/page/Overview.html
Hi Dominik,
Hope this helps!
Yeah, it's frustrating.
You describe my normal way.
However, I cannot wipe with "Return to Service" because they have already lost the connection.
In my opinion, using the app has two disadvantages for me:
1. I have to pick up every iPad.
2. Student codes prevent easy access to iPads.
I discovered that the issue is a security feature implemented since iOS 18:
iPads and iPhones will reboot if they aren't unlocked for 72 hours. The reboot cuts off the Wi-Fi connection. Unfortunately, I don't have a solution for this problem yet.
It seems that this is a common Problem. We noticed that all our Ipads are randomly loosing the connection to the jamf server. They are then marked as "inactivated" Even if the WLAN connection was always on. Only soluton yet is to reboot every Ipad by hand. We have 450 Ipads in use and you may understand how annoying that is.
I hope Jamf comes up with a solution soon.
Perhaps Jamf will create a way to disable this "feature" or change the time to any hour, day, or week.
As an administrator, this just creates unnecessary work for me.
Well, seems that no one cares...
