Chrome Update
  • December 15, 2021
  • 7 views
rajrajan
Dear All,
Question on the Chrome update.
All the devices are set to Auto Update and are on. However, the update only starts when I go to About Google Chrome and get this message "Nearly up to date! Relaunch Google Chrome to finish updating."
How do I force the update to all the devices? This means that Google Chrome will update automatically every time. And I don't want to repeat this every time.
Currently, this has been done:<key>updatePolicies</key>
<dict>
  <key>global</key>
  <dict>
    <key>UpdateDefault</key>
    <integer>0</integer>
  </dict>
</dict>
1 reply
  • December 15, 2021
Usually that happens without any interaction for us.  A few times I have had to install Google Software Update.  See this link step 3 2nd bullet.
https://support.google.com/chrome/answer/111996?hl=en
Other thoughts: I do think the updates are staggered by default and not all computers will get them at the same time.
