SplashBuddy - Dummy questions
  • October 18, 2019
  • 0 replies
  • 16 views
I am new to splashbuddy and followed the kickstart guide and want to use it for normal package deployment(so not dep related)
I made the package and first time I run it, splashbuddy appears so it works.
But If I want to run it again, fx made a new package and try to use on same Mac it does not start. I have tried to remove the launchagent etc, but It wont show up
2nd question I have if regarding naming. If I upload a package to jamf called autoupdate-2.0.pkg - in the packageName in the xml file I then write autoupdate. So should be working I guess.
But If I create the package and manually launch Splashbuddy it just looks like this and nothing more happens
