DEP and computer names
  • March 11, 2016
  • 5 replies
  • 61 views
Forum|alt.badge.img+20
Hi Folks,
We have our DEP setup in our JSS and the computers and the iPads are all showing up just fine. What I am struggling with is the computer name piece. I know we can assign names based on serial number, MAC Addresses or a list of computer names.
Am I missing something because I don't see how the computer names list is supposed to work. I can see the list from Apple and I can reconcile this with our inventory of new equipment so I know what asset tag is assigned to what computer and its serial number.
So with that in mind, how do I create this computer list and what are the requirements of the list so I can use it appropriately? Anyone else using DEP with their JSS? I know I have to name the computers correctly in order to bind them to AD.
Thanks
  • March 11, 2016
I've struggled with this as well, particular since the _mbsetupuser means you can't count on GUI access to prompt a technician for a name during automated enrollment. Right now I'm generating temporary names with a script, and then changing them once enrollment is completed, accepting that the AD name won't necessarily match.
If you're not averse to scripting and slugging the names into a file somewhere, you could use the jamf setComputerName -fromFile feature.
There are feature requests related to this dealing with this problem, so there is likely to be a more elegant solution in the future.
stevewood
Forum|alt.badge.img+38
  • March 11, 2016
@mconners I think you are mixing two different things up: DEP and PreStage Imaging. With DEP there is no way that I know of to provide a list of serial numbers, MAC address, or computer names to name a computer. However, there is that mechanism with PreStage Imaging.
Currently, as far as I know, there is no way to pre-populate names for your devices in DEP. I may be wrong about that, but I've checked my DEP workflow, and I do not see a way.
The only method would be to do something like what @joshuasee mentioned, and script the naming of the computer. Depending on your naming convention, you could use a Policy set to trigger on "Enrollment Complete" and re-name the computer before binding to AD.
ImAMacGuy
Forum|alt.badge.img+23
  • March 12, 2016
we setup a self service policy, the machine is enrolled, self service auto-open, they go to the section and runs the Self Service policy, which prompts for computer name stuff, it's worked pretty well for us.
  • March 15, 2016
Thank you for feedback, this has been helpful.
Steve, you are right, I think I may have been mixing the two of the things together and I didn't mean to do that. We can easily grab a Mac off the list and add it to the workflow and all works well. It is during the pre-stage imaging phase that is causing some angst as you have mentioned.
John, is there any chance you could share your workflow/script for naming the Macs via self service? Just curious how you have it working.
Thanks again!!
mick
ImAMacGuy
  • November 9, 2016
#Freddie Cox for Knox County Schools
#Edited by Justin Ellis
#2012
COUNTRY=`/usr/bin/osascript <<'EOT'
    activate
    set COUNTRY to text returned of (display dialog "<enter dialog here>" default answer "" with icon 2)
end tell
EOT`
REGION=`/usr/bin/osascript <<'EOT'
    activate
    set REGION to text returned of (display dialog "<enter dialog text here> "" with icon 2)
end tell
EOT`
MODEL=`/usr/bin/osascript <<'EOT'
    activate
    set MODEL to text returned of (display dialog "<enter dialog here>" default answer "" with icon 2)
end tell
EOT`
TAG=`/usr/bin/osascript <<'EOT'
    activate
    set TAG to text returned of (display dialog "<enter dialog>" default answer "" with icon 2)
end tell
EOT`
ComputerName=$COUNTRY$REGION$MODEL$TAG
#Set New Computer Name
echo $ComputerName
scutil --set HostName $ComputerName
scutil --set LocalHostName $ComputerName
scutil --set ComputerName $ComputerName
echo Rename Successful
