Jamf Self Service issue with apps installation
  • August 26, 2023
  • 34 views
I'm trying to push Sophos onto a machine through Jamf Self Service and when I click install it says done but the app doesn't install. I've packaged Sophos using Composer and use the same .pkg for a Sophos policy which is pushed out to all the devices and this pulls down and installs. Any idea what I could be missing?
VS59_2
  • August 27, 2023
what happens if you try to manually install that .pkg file? And what does the logs of the Self Service policy says?
AJPinto
  • August 28, 2023
Dosen't Sophos have a specific method of installation? Did you follow their guide on how to install the client with JAMF? If not I recommend following their guide. If you did and are having issues, you should contact Sophos.
https://doc.sophos.com/central/customer/help/en-us/PeopleAndDevices/ProtectDevices/EndpointProtection/MacDeployment/index.html#create-sophos-installation-script
paul_r
  • August 28, 2023
I've seen this with other applications as well. It seems like the Install button just queues an install and doesn't wait for it to actually finish.
