The default color scheme used for Jamf Protect GUI has a basic Red/Green color use. This makes differentiation between desired and non-desired states almost impossible to read in the dashboard and other GUI elements for traditionally color-blind populations.
Page 1 / 1
This should almost be a feature request for cololblindness frendly UI.
I'd just bring it up with your customer success manager. I think you will find them very helpful
