lpadmin - Group not found
  • April 30, 2019
  • 20 views
Hello all,
I feel like i'm going insane.. for as long as I've been imaging Macs I've been adding users to the print operators group using the following command:
dseditgroup -o edit -n /Local/Default -u admin -p -a everyone -t group lpadmin
Ever since Mojave, i get the error "Group not found". Ive tried every variation i can think of
sudo dseditgroup -o edit -n /Local/Default -u admin -p -a everyone -t group lpadmin
dseditgroup -o edit -n /Local/Default -a everyone -t group lpadmin
dseditgroup -o edit -n /Local/Default -a everyone -t group _lpadmin
etc..
When i run dscl . read /Groups/_lpadmin. i clearly see the group there. When i go to Directory editor i see the group there. What am i doing wrong? Thanks in advance!
1 reply
  • May 1, 2019
Update after moving the commands around i was able to get terminal to accept the command.
So it asks for the admin password and looks like it accepts it but nothing happens. The print preferences are still locked. Any advice on how to give full rights to the print preferences to standard users? THANKS!
